What is this
icprncss
Checking my product library, I found this
PostgreSQL CMS
It's a manual entry. Did the CMS change or what? What exactly should I do with it?
icprncss
PostgreSQL CMS
http://www.daz3d.com/forums/discussion/41482/
New version of Studio with a CMS replacement. Read the thread first.
i don't see a manual option. it's only for people who use install manager.
The product page states it was manually added to the list. As in I didn't buy it. I found it odd as DAZ does not usually make a point that something was a manual addition when they add things to your product library.
PostgreSQL CMS is a new database for DIM, replacing the old Valentina database. I suspect they "manually" added it to the product library so it would show up as an item in your Ready to Download tab of DIM. If you, as I, don't use DS's Smart Content, then you don't need it, but I downloaded it through DIM in any case.
From what I understand, the newPostreSQL CMS works much better than the old Valentina database did.
I gave up on smart content quite some time ago because I really did nothing for my standard work flow.
I was originally told that if I didn't install the CMS, things like auto fit and/or auto follow (I don't remember if it was both or one of them) would not work if the CMS was not running.
So, does this new CMS replace the old CMS completely or do I need to have both installed? The link posted above doesn't really make it clear.
Replaces it completely. No longer runs all the time, just when DS or DIM are running. Much much faster for me using 64-bit, and much more stable.
