Error Message when trying to install Bryce Pro Advanced Lighting 2
Hey all, got this error message when trying to Install David's Bryce Pro Advanced Lighting 2 via Daz Installer.
Here is the error message:
"Install Manager cannot find a required path. The package for "Bryce Pro Advanced Lighting 2" requires that the installed path for "Bryce 7 Pro" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again. "
Not being computer savvy in the least, I don't know what this means. I'm running Windows 7 Premium. Thanks for any help.
In DAZ Install Manager, click the cog icon in the upper right corner (Settings), then go to the Applications tab. Click the plus sign in the lower left and select Bryce under name. It should full in 7 Pro under version and 32 under bit. On the Path line click the 3 dots at the right and browse to where Bryce.exe is located, (e.g. C:\Program Files (x86)\DAZ 3D\Bryce7) and hit Accept. Then you'll be able to install Bryce content.
Thank you very much, fixmypcmike. That worked perfectly :-)
