Victoria 4.2 and Michael 4 removing default underwear?
I am new to the 3d scene, and recently started using Daz3d Studio 4.5. When I load Victoria 4.2 or Michael 4 into a scene, the default image shows them in basic underwear. How do I make them nude, so that I can use different underwear, or none at all. I am still learning and can't find a tutorial that covers this... Thank you.
You need to apply a different skin to the characters. There should be a skin without The clothes in your textures folder. V4 has a matpose to apply the texture, which shows as !All_Natural_NG I am not sure if M4 has a similar mat pose, you may need to apply the texture manually.
You may better to serch ds mat script. (for ds, daz offer daz studio companion files, you may need not serch poser mat poze files)
there are several ways, if you use Content library ,
Select V4 in scene, then go to Content library (tab or pane)
DAZ studio Formats >your library (contents root directory)>people>Victoria4>Materials >V4 sample Res.
you may find three image icons with Material(s) tagged.
click !All_NAtural_NG.dsb . it apply texture and set value for each proeprty (of daz default shader.) on V4 surfaces.
About M4, in M4 sample Res dirctory, there seems only two mat scripts.
No mat , or with boxer pants texture ^^;
But if you can find V4 (M4) Standard res,,under the Materials directory,
there are many material scirpts,, it offer you more variety and qualitie .
(I do not remember which product include these Standard mat scirpt files. so that I can not say
you have them or not)
