smart no more (Solved ! )
efron_24efron_24 Posts: 478
Suddenly the Smart content does not work any more
"Filter by content" does not show much of all I have...
When I click that off every product is still in the list
but of course mixed... so all together.... from male to female from V3 till g8... that is a bit toooo much :D
So I click Genesis 8 and only a few options
see attachted images
I did see a message about failed metadata come by
5 succeeded 1 failed
but have no idea what that is
Post edited by efron_24 on
  • Did you load Freya by the character preset? From other posts I believe that is not correctly set up - try loading the Genesis 8 Female base, then apply the frya 8  shape from the Parameters pane and the materials from the product instead.
  • efron_24efron_24 Posts: 478
    It is strangely with all G8 women incl the base figure
    not G2, G3, not animals.. not the males (g / g8)
    Freja was good for 2 days.. but i will try to see if i can do what you say
    Technical things :D
  • Not sure if that is what you meant but it seems that your smart content filter does not show your G8F-specific assets when you select a Genesis 8 female. If that's the case I had the same problem. What did the trick for me was to delete the Genesis 8 Female Starter Essentials and reinstall it again.
    edited October 2020
    Geee That works indeed !!!!!
    Thanks A lot !
    Strange !! any idea what causes this to happen ?
  • Happy to help! Can't tell for sure what causes this but I assume it has something to do with installing new content.
