Help with removing a wall *solved*
Fae3D
Ok, so I know there's a way to remove or remove opacity on a wall in Iray, I just cannot remember what it's called so that I can search Youtube on how to do it. I'm working with a room that is one solid box, and I need to remove the wall in front of the camera, and maybe the ceiling. Does anyone know what I'm talking about?
Post edited by Fae3D on
geometry editor. save the materials of the wall, then select the polys of the wall, assign a new material zone to them and then reapply the materials and you can then turn down the opacity when you want.
https://www.daz3d.com/forums/discussion/273706/making-a-wall-ceiling-invisible
“iRay section node”
That's not the one I was thinking of, but that might work too, thanks!
That's the one I was thinking of that I couldn't remember the name to! Thank you!!!!
