DAZ Content Management & Bryce content
Daniel Barnett
MY DAZ Content Management app shows and installs only 3 Bryce products I've purchased! I've purchased more than 20 products. Do I need to manually install these products?
Thank you!!!
dbb
Are you talking about Installing with the DIM ? The Content Manager is for DS
DIM (DAZ Install Manager) is for all Apps
If so have you mapped the path correctly to your Bryce installation.
What content is not appearing to install?
Thank you for your reply!!
Yes, I'm using the DIM app for installing all content purchased at DAZ. I use all of DAZ applications (Studio Pro, Carrara, Byrce & Hexagon). I do have the applications path listed in the DIM settings.
It is an extensive list which I can type but I'll need a little time to do that. I'll need to cross reference what is in the DIM installed against my Product Library.
Do you know where I can find a list of the Bryce folder structure? Maybe I should ask about Carrara's folder structure too!
Thanks again for your reply!!
dbb
Horo made a very helpful PDF about installing Bryce content
http://www.horo.ch/docs/mine/pdf/BryceContent_v4.pdf
This is a screen shot of part of one page of it
Thank you! This will help me to clean the folder up. Also thanks for the link to the PDF.
dbb
