Temptation and Drama on Genesis 1?
Hi guys,
Does anyone know if the Temptation and Drama set (for G2F) will work on Genesis 1 females like Victoria 5 or the Genesis teens?
(http://www.daz3d.com/temptation-and-drama-for-genesis-2-female-s)
  • fixmypcmikefixmypcmike Posts: 19,696
    No, you would need to use GenX2 to transfer the morphs to Genesis 1
  • edited December 1969
    Hmm.. $50 worth of software to be able to use a $20 piece of software. I guess not.
    Shame. :-(
    Thanks.
    Morphs only work on the figure they're designed for. That's because the vertex order is crucial when working out which of the thousands of points it should move, and this will vary from figure to figure.
    GenerationX2 will allow you to convert any Genesis 2 morphs to Genesis and vice-versa, so it's more like $50 of software to use hundreds of dollars of morphs.
  • Scott LivingstonScott Livingston Posts: 4,348
    For Genesis 1, I highly recommend 220 Emotions for Genesis which is by the same creators as Temptation and Drama. I own both of those products and have gotten lots of good use out of them.
