HD figures
inspired_designerinspired_designer Posts: 63
Can you modify an HD figure with imported morphs or mix with other daz figures?
  • fixmypcmikefixmypcmike Posts: 19,708
    Yes, you can mix HD morphs with other morphs.
  • Richard HaseltineRichard Haseltine Posts: 109,387
    It isn't the figure that's HD, just the morph - the figure is the same one as before, with it's standard material, morph and pose options but it's also been given a moprh that works on it in the high-resolution subdivided state. We can't, however, edit the HD morphs themselves or create new ones for ourselves.
  • inspired_designerinspired_designer Posts: 63
    Thank you
    That is exactly what I was looking for.
  • scal.64.psscal.64.ps Posts: 140
    Hi,
    Just wondering whether the basic G2M and G2F could use the HD at the moment ?
    Thanks
    If it's a standalone HD morph, yes. For things like Victoria 6 HD, they are refinements of the basic Victoria 6 shape and so won't work as designed, if at all, without Victoria 6.
    Thanks Richard,
    Anyway i'm still a bit confused by all of this...
    So actually, we can buy V6 And V6HD, S6 and S6HD, M6 and M6HD, ...
    I was just wondering whether both G2F and G2M would have their HD version released in a near future
    The HD products are additional, more finely detailed, morphs - they are the same base figure, but DS is doing something behind the scenes to move the additional points generated by the sub-division algorithm, instead of being limited to moving the base mesh as a regular morph does. So, yes, someone (DAZ or a PA) could make a set of HD detail morphs that were designed to work on the base mesh as well as or instead of one of the named shapes.
    thanks again Richard... well, i guess i just have to wait now :)
