How to use DzInstanceGroupNode Class ?
Using DzInstanceNode sample code from Rbtwhiz, I create a script for duplicate and locate multiple instances but it's slow.
Using my script : 3 secondes for 100 duplications.
Inside daz studio using the "New node instances" function : no waiting time.
The DzInstanceGroupNode class seems to do the job but I really don't understand how to use it.
Any help ?
Julien
The Create > New Node Instances... action is compiled C++; i.e. a plugin built using the SDK. The Create Instance sample is a script. A script will run slower than compiled C++. Interpreted languages are typically slower than compiled languages in general.
A DzInstanceGroupNode is designed to reduce consumed system resources. I've added a Create Instance Group sample to show how its used. It will run slower than the compiled C++ equivalent; i.e. Edit > Object > Instances > Group Like Sibling Instances.
-Rob
Thank's a lot. I update my script. It's not faster but it's better.
I don't know the purpose of sibling instance, Now I understand.
Next step : Distribute instances over a surface... Like a tiny ecosystem.
Create a plugin is another adventure. 32/64 bits Windows/Mac...
Julien
