How to get joint orientation by daz script
ftd1992ftd1992 Posts: 0
I want get joint orientation by daz script, but fail.
Some joint result is true like Left Shoulder Bend,but some joint result is error.
I need help.
(function () {
function radialAngle() {
var pi = Math.PI;
return 180 / pi;
var bone = Scene.getPrimarySelection();
var nAngle = radialAngle();
var rot = bone.getLocalRot();
var rotOrder = bone.getRotationOrder();
var o = bone.getOrientation()
oEuler = o.getValue(rotOrder.firstAxis, rotOrder.secondAxis, rotOrder.thirdAxis);
oEulerD = oEuler.multiply(DzVec3(nAngle, nAngle, nAngle));
print(oEulerD)
  • Moved to the scripting forum. I'm afraid I don't have anything constructive to add, other than to point out that the lined button with <> at bottom-right will give you a box you can post code into so that it keeps its formatting.
  • OmnifluxOmniflux Posts: 432
    What error are you seeing and on which joint?
    I have no error on G8F Left Forearm Bend, although the result with your script does not match the values in the Joint Editor (it does with Left Shoulder Bend).
