Shoe Soles
davidjones8418
I expect this has come up before, but I can't find anything on it. Nor could I find a product, but if there is one please direct me !
Not all shoes have soles. Some are just flat. The ability to add a plane to the bottom of a shoe that matches the shape of the sole, with different sole like textures available (leather, rubber, grippy, smooth), would be a godsend for the flat soled shoes in my collection.
Not sure what you're looking for here.
Could you just change the sole material for the shoes you already own?
Like, use a shader and change the material/texture yourself?
Or, do you mean a product line like this , where you ADD different kinds of soles to get the shape you want?
https://www.daz3d.com/patchwork-shoes-boots-3-and-4-for-genesis-3-and-8-female-s
And more info on adjustable heels/shoes
https://www.daz3d.com/forums/discussion/comment/5884726/#Comment_5884726
Oh and I just stublmed across this, looks pretty cool too..
https://www.daz3d.com/all-season-shoes-for-genesis-8-females
and more textures for them
https://www.daz3d.com/all-season-shoes-texture-add-on
The problem for the shoes in your collection is that they will each have a different uv-map and slightly different shape so you won't get a one-fits-all solution by adding a plane. Your best bet for those, as Griffin Avid suggested, is to use an iray shader that includes a bump/displacement/normal map to give the impression of grip.
There are some nice shoes there for sure. However, they don't really fit the Sci Fi setting I like.
I have the shoes I like, but many seem to have plain black 2-dimensional soles. While I can add a texture to these, the texture seems to travel onto the wrap-around sole surface. Also, of course, the texture just repeats whereas with real shoes, they have unique soles, like this (attached).
It would be a nice detail to have.
Maybe not worth the time and effort for the payoff, I don't know - and maybe not possible at all. But, you know, turn any high heels into Louboutins, etc.
I would buy it anyway : ).
^The thing you're looking for depends on the uv-mapping. There won't be a general solution that can fit all shoes. On a shoe-by-shoe basis, you can draw a black and white map on the current shoe texture map and use that as a bump map - but it would only work for that shoe. Iray decals might work but I haven't used those enough to know for sure.
