Help. Materials won't export with .obj file
I'm surely missing something, not checking a box or something. I can not get any materials or surfaces to stick to an obj file when I export it. When I export the file out as obj and import it back into Form-Z none of the surfaces import and open with the model. I've spent half the day trying to figure this out. I finally raised the white flag and called tech support at Form-Z to see if it was an import issue. They can't figure it out either. They have tried to import my obj file in a number of additional softwares and those apps won't load the materials either. Any one have a clue what I'm doing wrong?
    Try checking the Collapse UV Tiles box.
  • If you mean "textures aren't applying when I import", have you checked the matching .mtl file (it gets loaded at the same time as the .obj file) to make sure it's causing DAZ|Studio to look for the texture maps where they actually are? There's a lot of Weird Stuff™ that can happen with .obj import/export, and mismatched texture folder paths is one of the common ones.
