Lost access to ALL content since installing Beta version
Hi - how can I get content into my DS Beta version? Since installing it (to avoid issues with the Smart Pane and vanishing content!) I have access to nothing... kind of ironic...
I'm sure it's a simple process but I don't know what that is. :down:
Much appreciated!
Check in the Directory Manager to be sure your Content folder is mapped. It should be mine was.
Then go to the Content DB Maintenance menu and do a Re-Import of your Metadata.
The Beta uses its own Database controller to stay 100% separate from the FULL version on your PC.
The beta doesn't share settings with the general release, so you need to set up your content folders.
Hmmm... maybe I should have mentioned that I'm on a Mac. I'm not understanding any of this, Jaderail
fixmypcmike - set up content folders? Is there documentation on this?
I feel like I waded into a swamp when I just wanted to keep my Smart Pane from crashing...
On the Content Library pane click on the Options menu (rectangle with horizontal lines in the upper corner) > Content Directory Manager
Make sure the folders listed for DAZ Studio Formats and Poser Formats match what you had in the general release.
DAZ Studio has the SAME folders on a Mac as a PC. Just some in different Menus...
This is what I mean for Directories...
This is how to get the DB maintenance...
Thanks for taking the time to post these Jaderail. Being visual, this helps a lot!
Your Welcome. It's my way of learning as well.
