Export clothing I created
I created a simple shirt for V4 that I weight mapped using the transfer utility and then did some fine touches to the weight maps (After converting V4 to TriaX weight mapping).
How do I export this new shirt so that I can share it with others?
You find the Data Folder. You find your Author name used at Save and there it is. But its not that simple.
You need a Zip file that holds a Data folder and it holds only your item.
Then you need the texture files which should also have been Inside the DAZ Studio content folder in either the Materials folder or the Runtime/Textures/Your textures Here when it was created.
You also need the load Icon and maybe a Material File with Icon as well.
All this needs set up properly in a Folder that holds the other Folder structures that gets Zipped so the End user can just do a Unzip, and then can merge the sub folders into their content folder.
