OT Keep your 3090
in The Commons
I just want a stable version of Windows.
More BSOD. System service exception. I try some diagnostics. Running Verifier and it won't boot now, getting an unmountable boot volume error.
I assume you mean you have a 3090 installed and had crashes, and now have an unbootable system. Obvious question is did you check the power was adequate? And what are the rest of your system specs?
Is the card a tight fit?
Even if it isn't, is it properly seated in the slot? It can be worth removing and re-inserting even so.
keep your 3090, what i want is some completely unrelated request that isnt mutually exclusive
Contact the manufacturer. Depending on who it is they may crossship. But if it is warranty they will replace it.
