How to "Create Custom Action" for pose convert script. [Solved]
lukon100lukon100 Posts: 849
edited September 2020 in Daz Studio Discussion
A freebie download page for a pose convert script set recommends I use something called "Create Custom Action" to make the scripts useable. It does not explain how to do this.
All it says is put the scripts into the library and do this mysterious "Create Custom Action" thing.
I put the scripts into my Scripts folder, but CMS won't display them. What do I do?
https://www.renderosity.com/mod/freestuff/?item_id=77430
Post edited by lukon100 on
  • NorthOf45NorthOf45 Posts: 5,770
    They'll only show in the Content Library, no Smart Content. Did you refresh the folder? If and when you do see them in the scripts folder (or any other, as they say), multi-select the three scripts, right-click on one of them and select "Create Custom Actions", then choose Favorites or Scripts. You can use subgroups, or re-arrange them later with Customize (F3).
    Thanks for your help, NorthOf45.
    It was an error in my thinking. I was looking for these scripts in the "My Categories" section of CMS. They were not there because I forgot that I first had to manually copy them to there from the "My Daz 3D Library" section of CMS.
    Whoops.
