Doubt about Iclone 7 after the end of the trial period.
ChrisSerket
First of all, I don't speak English so I'm using Google Translate to write to you.
I know that the question that I put should have been placed in the Reallusion forums, but personally I don't trust the wonders that can speak there, and as I know that here there are several users who use Iclone 7 for animation or only to capture movement and then to use it in Daz Studio (as would be my case or so I hope).
Well, in a Daz forum I thought I read (I think it was from WendyLuvCats) that once the Iclone 7 period is over it can continue to be used (the typical window does not appear that if you do not activate the program it automatically closes and you cannot use it ) but with many blocked or ultra limited features.
That's right?
And if so, among the functions that remain available are those of exporting in Bvh animation format and those of motion capture?
My idea is precisely to use Iclone only for mocap and then return it to Daz Studio, since even the super pipe (very expensive) that sends Daz models to Iclone arrive in a depressing way (which is not worth all the money it costs, or so I have seen according to several videos on youtube or forums both from Daz and Reallusion). In my opinion, it is because it uses an fbx file as an intermediary, and an fbx will continue to be an fbx no matter how well exported it may be, since its limitations are the same as if it is exported manually.
My current idea is to send to Iclone characters mainly from Genesis and Genesis 8, either in a conventional fbx or maybe using that pipe (if it convinces me in the future), and only use it in Iclone to capture the movement and then export the motion file in BVH to print it in the DUF file where the original model is in DAZ.
I hope someone can guide me a bit on this matter.
Regards.
I actually have no idea if iC7 can be used after the trial period
it was not me that said that, I only have iC6
it used to be you were limited to content in the program and standard sized renders, no export or import
but I don't know if that is the case now
I have never done mocap or owned such plugins either
I understand, then I will have mistaken user or I misunderstood. Apologies.
