Carrara Community Art Gallery - Show us your Renders!!!
1235761
  • mschackmschack Posts: 337
    WIP music studio.  Trying to get a realistic interior effect without Indirect lighting.
    1920 x 987 - 2M
    and some sci fi action...
    1600 x 872 - 1M
  • DiomedeDiomede Posts: 15,401
    Looking great, @mschack.
  • DartanbeckDartanbeck Posts: 21,988
    Agreed!!
  • DesertDudeDesertDude Posts: 1,239
    edited September 2020
    Agree! Great renders mschack.
    Can I ask, are you using 'regular' lighting or the more expensive / render intense  Global Illumination, which has other more expensive render time components?
    The nice blue shadows on the snowy landscape look great!
    I'm a bit obsessed with atmospheric perspective landscape stuff. smiley
    Post edited by DesertDude on
    Thanks for positive feedback guys!
    Hi @DesertDude i understand your obsession!  I too am trying to find ways to make my Carrara renders look more realistic.  I am not using Indirect lighting in any of these renders.  In the outdoor scenes the atmoshere mostly comes from Carrara's Realistic Sky's Fog setting.  It basically does most of the work and creates the nice depth cueing.  I found the fog and haze only work well in large magnitude scenes though.  As for the blue shadows, the Realistic Sky control has a "sky colour" setting under the "atmosphere" tab which takes over the general Scene ambient settings colour.  The general ambient control then switches to a brightness slider.  In this case I made the colour a lightish blue and the brightness control is at 21%.  Usually the brighter the scene the more ambient lighting you can get away with.  All these things need to be tweaked of course depending on youir scene and what looks good to you.  The snowy scene renders in 1 and a half minutes, the scifi scene in 30 seconds.  Another trick since there is no GI is to add other lights to the scene.  In the scifi scene the mid distance hills and the distant mountains on the left are lit with a spotlight to make it look like the sun is shining through.  Using the light cone on the spot you can also achieve a god ray effect.
    I have been experimenting with ways to create an ambience effect in Carrara, and find the best method so far is to place a spot in the scene that shines across the cameras view using the light cone, but where you can't see the edges of the cone.  Adding turbulence to the light cone gives a nice atmospheric effect that you can see in my indoor render above.  The light cone almost adds it's own ambient lighting to things but note that it tends to wash out shadow areas in the background.
    I do like Carraras indirect lighting and find it most useful for indoor scenes where you are specifically trying to achieve a look with only one or two light sources illuminating the entire room.
    I would like to know what others have come up with, does there happend to be a thread just for realistic rendering tips/tricks? Or should I start one :)
  • video
    Thanks mschack for the explanations.
    Nice tip using a light cone. Cool yes
    Here are a few links to some experiments I did using Realistic Sky vs. using some of Carrara's Multipass render options, along with cooking up some of my own custom mattes, some of which may or may not have been necessary, just experimenting. This link has 4 posts with examples and screen grabs:
    https://www.daz3d.com/forums/discussion/comment/3421681/#Comment_3421681
    This was another quick experiment using Realistic Sky only
    https://www.daz3d.com/forums/discussion/comment/3619976/#Comment_3619976
    Here is one more, but the image seems gone from the original post so posting again. Same technqiues using multipass renders and assemebling in a compositing app. Not sure how 'realistic' it is, might be kind of 'Candyland-ish'.  smiley
    640 x 480 - 176K
    video
    That's friggin cool Wendy! yes
    That is amazing Wendy. Lighting is awesome!
  • Wendy, you must have assigned emmisive surfaces to just about everything. smiley  You are sure making a case for Octane.
    Some interesting tips there, thanks!  Sometimes I just put a plane in front of the camera to act as a filter, and start experimenting with textures and transparancy.
    I have been tempted to start a photo-realism thread.  There currently is an NPR thread, and it has been super valuable.
    Handdrawn stuff is so seductive.  But making a render look more real is cool as well.  If you want to start a PR thread, please feel free!
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,485
     it's just the default Howie Farkes Darkwald scenes (with the details  and lighting dropped to 4)
    I interpolated it with DAIN-APP 8X after rendering and added some BorisFX Particle Illusion in post
    is not Octanedevil
    great renders by everyone
    sometimes Carrara terrain renders do need a little post colour grading hue/ contrast etc adjustment because they seem to look as though they use the cheap Agfa film I used to buy as a teen for my holiday snaps cheeky
    maybe some of those LUT files mentioned elsewhere in an image editor
    hey @UnifiedBrain, I have tried the textured plane idea too, though I have found it kills all the post render effects such as lens flare.  Is there a way around that?
  •  it's just the default Howie Farkes Darkwald scenes (with the details  and lighting dropped to 4)
    is not Octanedevil
    Well, that is good to know!  I have Darkwald, but have never opened it.  If the default lighting is that good, you might consider modifying it for use on future videos. :)
    What do you mean, "details and lighting dropped to four?"
    Also, how did DAIN affect your video?  Did it make the slowmo smoother?
    Always trying to learn, thanks. :)
    Yes, I remember some problems in trying to mechanically create layers in the assembly room (as opposed to creating layers in the texture room).  But these were just experiments, and I likely didn't resolve them.  I think it also makes a difference if you are going for realism, or more of an artistic effect.
  • it is slow enough without improving the default lighting more IM
    I usually go the other waycheeky
    in the render settings the detail was 1 and lighting/shadows 1 which is unnecessary for a HD animation and terribly slow, I drop that for most things, it's basically your pixel filter and shading rate to use the DAZ studio equivalents
  • Sorry, I have no idea what you just said.
    What does DAIN do for your video?
    I have never seen a "1 detail" or "lighting/shadows 1."  Where are these located?
    What is "IM?"
  • I mix my softwares up in terminology a lot blush
    its object accuracy NOT detail
    and Shadow Accuracy
    was not on my computer typing that and iClone was the one I confused the terms withcheeky same effect
    IM is in my with the O for opinion accicidently droppedblush
    I suffer Typoneseblush
    DAIN-APP is an AI interpolation software that calculates inbetween frames, I render 100 and interpolate to 800
    237 x 360 - 30K
  • Ahh, now I get it, thanks.  I rarely even touch those controls these days.  Just not that much difference, even in single frame renders.  Unless you like to wait. :)
    Regarding the DAIN app, what kind of difference do you see after using it?  In other words, how is it benefitting you?
    less time rendering
    100 frames is 8X shorter than 800
    those Darkwald scenes took 5 hours each
    the last one sadly didn't interpolate well as too many big camera pans
    Needs more shrubberies!  Btw hair makes great weeds, and you can style them!
    1600 x 807 - 2M
  • StezzaStezza Posts: 8,871
    great image @mschack and use of Carrara hair yes
    how long did it take to render?
    Thanks!  I cranked up the antialiasing and it took about 11min.  Just using ambient occlusion.
    yes awesome.. my kind of render smiley
    Fantastic!!!
    Gorgeous!!yes
    Gorgeous!!yes
    You're Gorgeous!!!
    Is nsfw images ok in this forum?  Nothing explicit of course.
    Thanks @DesertDude and @Dartanbeck
  • Bunyip02Bunyip02 Posts: 9,288
    https://www.daz3d.com/terms-of-service
