v9.0 -- mcjBuilderA - script to build anything in Daz Studio - updated sept. 16 2017
15791011
  • mCasualmCasual Posts: 4,607
    edited May 2014
    Miss B said:
    Ohhhh, nice sconce. :coolsmile:
    thanks i can add the word "sconce" to my English vocabulary :)
    1920 x 1080 - 760K
    Post edited by mCasual on
    edited May 2014
    presently testing all the test paths i made so far
    this way i can find out when incompatibilities crept in
    for instance, using a name with capital letters in a "define" which had become a fail
    and using the "description" (comment) command which had become illegal
    figure 1 - blender cycles 3000 passes, direct light less realistic but also less noisy and faster to render
    1920 x 1080 - 477K
  • RAMWolffRAMWolff Posts: 10,345
    OMG.. that looks really good. Better than some "for sale" stuff out there!
    edited May 2014
    though the Blender-Cycles renders help make it look good
    about 1/3 of the tests done !
    i'm aaaaaalmost sure i'll post version beta 6 tonight
    Figure 2 - thinking about bagels and pretzels for some reason
    960 x 720 - 146K
    1920 x 1080 - 734K
    edited May 2014
    good news ! the 113 sample extrusion path scripts have been fixed
    ( or in some cases the script has been made compatible with them )
    so in the next minutes, i'll package Beta 6 and post it here
    later this week i'll bring the user manual up to date
    1000 x 400 - 69K
    1000 x 400 - 40K
    * * * major Update - Beta6 * * * * * * major Update - Beta6 * * * * * * major Update - Beta6 * * * * * * major Update - Beta6 * * *
    it's still in Beta but the 113 sample extrusion path scripts ( which were in fact test files ) were tested and do produce interesring shapes
    this should reduce pain :)
    the manual will be updated this week
    ======> https://sites.google.com/site/mcasualsdazscripts3/mcjbuildera
    800 x 800 - 23K
  • Miss BMiss B Posts: 3,071
    Actually, I'm not sure if it really is a sconce, or only the ones that are made of crystal are. It was the first thing I thought of when I saw it.
    I like your render . . . very kewl. :coolsmile:
    Ohhh, just dip it into a large bowl of salt, and you're all set for pretzels. :coolsmirk:
  • TugpsxTugpsx Posts: 800
    Nice new toys to play with. Thanks again
  • Robert FreiseRobert Freise Posts: 4,587
    A sconce is a type of light fixture affixed to a wall in such a way that it uses only the wall for support, and the light is usually directed upwards, but not always
    Cool script looking forward to using it
    Ahhhh, so there's no open bottom to let the light flow downwards. OK, I'm picturing in my mind what you're referring to.
    Thanks for the definition Robert. :coolsmile:
    Your welcome
    Used to be an electrician and installed many of em
    Some do let light out the bottom like the wall mounted bathroom light over the vanity
    Your welcome
    True, but the ones I've seen for bathroom lights are just in reverse. IOW, they don't have light coming out the top. They're pointing downwards instead of upwards.
    edited May 2014
    ** ~~ ^^ vv^^ ~~ ** ~~ ^^ vv^^ ~~ ** ~~ ^^ vv^^ ~~ ** ~~ ^^ vv^^ ~~ ** ~~ ^^ vv^^ ~~ ** ~~ ^^ vv^^ ~~ ** ~~ ^^ vv^^ ~~ ** ~~ ^^ vv^^ ~~ *
    ** new Luxurious Manual for Beta 6 **** new Luxurious Manual for Beta 6 **** new Luxurious Manual for Beta 6 **
    ( just kidding about the luxurious part )
    At the bottom of the manual you can see the new features in Beta 6 : EndCaps, Maths and two new runtime variables : count and fr
    The PDF is only 2MB and found in the attachments section
    Fig 1. Fence made easy using the "count" running variable
    640 x 640 - 310K
    Thanks so much for the new beta and manual Casual .... hope I can around to working with this new script. :-)
    edited May 2014
    Welcome !
    still testing it and finding needed improvements
    here's a mildly complex path script to make columns
    its better to leve the ClosePath option off
    it will be the default state in the next version
    ClosePath off
    Tread 1
    PathUnits inches
    MoldSize 24 24
    ProfileUnits inches
    define crown x y z wx wz mn pn pw ph
    profile pn
    profilemirrorX on
    MoldSize pw ph
    setRot 0 0 0
    setPosX -wx/2+x
    setPosY y
    setPosZ wz/2
    Hardturn 90
    move wx/2
    Ring
    move wz/2
    Hardturn 90
    move wz/2
    Ring
    move wx/2
    Hardturn 90
    move wx/2
    Ring
    move wz/2
    Hardturn 90
    move wz/2
    Ring
    move wx/2
    Hardturn 90
    break
    setRot 0 0 0
    defineEnd
    define column x z wx wz height matname
    Material matname
    SetPos x 0 z
    MoldSize wx wz
    SetRotX -90
    Ring
    Move height
    Ring
    endCap
    break
    defineEnd
    define wholeColumn x
    column x 0 27 27 12 socle
    column x 0 24 24 120 big
    column x 14 12 4 120 medium
    column x -14 12 4 120 medium
    column x+7 12.5 2 1 120 small
    column x-7 12.5 2 1 120 small
    column x+7 -12.5 2 1 120 small
    column x-7 -12.5 2 1 120 small
    crown x 126 0 24 24 matcrown classic_ovolo 8 8
    crown x 117 0 24 24 matcrown square 1.5 2
    crown x 13 0 24 24 matcrown square 1.5 2
    defineEnd
    wholeColumn -12*18
    wholeColumn -12*6
    wholeColumn 12*6
    wholeColumn 12*18
    960 x 540 - 313K
    1920 x 1200 - 422K
    That's really cool. You could build your own kingdom with this script alone!
    edited May 2014
    for the technically inclined ( like Pisa tower architects )
    version Beta 6 doesnt include a HardTurnUp command but Beta 7 will
    in the meantime you can make one !
    define HardTurnUp ang
    RotateX ang/2
    SetScaleY 1.414
    Ring
    RotateX ang/2
    SetScaleY 1
    defineEnd
    and later on, use it like
    HardTurnUp -90
    in fact that's how i did it here
    to create the red polygon extrusion,
    next i'll use the path cap export feature and get my arched wall!
    i could also turn the path-cap into a "Profile"/Mold-shape and extrude it and use the "endCap Feature to cap it
    ... later that evening ...
    oh noooooOOooo the Tesselated triangulation failed for this extrusion path
    lets try is as a profile endCap ...
    Figure2
    ... well i did say it's still in Beta :)
    oh i think i remember now ... the ear clipping requires the vertices to be sorted so that the first one is in the lower left corner or something like that ... nah ... ? hmm
    Figure 3
    ... later that evening ... well i was able to make it work, it's possibly related to near-zero numbers ... Beta 7 will have perfected Tesselation ... stay tuned
    1920 x 1080 - 1M
    1920 x 1080 - 759K
    1920 x 1080 - 948K
    WOW! that's really cool. That last image esp!
    I have to agree. Stone arches are always a good thing. :coolsmile:
    edited May 2014
    i'll attempt to make arched ceilings (coutes) then i'll post the thing as a prop, and include the mcjBuilder Scripts that i used
    Figure 2 - Sainte Chapelle
    1293 x 1200 - 316K
    1999 x 1297 - 508K
    1280 x 851 - 772K
    1920 x 1080 - 441K
    You made that chapel?? OMG!
    edited May 2014
    the first picture only :)
    1920 x 1080 - 1M
    edited May 2014
    you know what's the trick for them arched ceilings?
    a picture frame for a picture of size 0
    hmm or 4 frame corners
    in fact it's horribly easier than my first attepts which involved tangent and cosinusses
    in your version of mcjBuilder you dont have the "arc00" extrusion profile
    but you could try using ... let me see ... classic_scotiaCove
    see the results using classic_scotiaCove in figure 3
    Profile classic_scotiaCove
    MoldSize 10 10
    profileUnits ft
    profilemirrorx on
    profilemirrory off
    closeprofile off
    PathUnits ft
    Tread 10
    Slope 0
    Radius 10
    ClosePath off
    WeldUVs off
    StepAngle 11.25
    InvertNormals off
    InvertUVu off
    RotateUVs off
    Repeat 4
    Ring
    HardTurn 90
    Ring
    Break
    Move -2
    RepeatEnd
    1920 x 1080 - 323K
    1372 x 654 - 104K
    1920 x 1080 - 569K
  • none01ohonenone01ohone Posts: 862
    And it all started with just one....
    I was going to say stone, but then thought bolt might be more apt.
    Amazing stuff Casual.
    edited May 2014
    with some pre-planning sketches and by working on small parts it's not too hard to make anything architectural or furniture
    1504 x 660 - 64K
    1920 x 1080 - 452K
    592 x 683 - 149K
    1920 x 1080 - 405K
    edited May 2014
    Beta 7 will include new profile curves and some corrections
    the keen eye may have noticed that the previous arch-ceilings had a UV map of length 0, since the extrusion nozzle was not moving
    but using one of the new curves and adding some movement, we get a usable UV map
    Repeat 4
    Ring
    Move -1
    HardTurn 90
    Move -1
    Ring
    Break
    Move 2
    RepeatEnd
    figure 2 : look at the civilized UV map we get !
    590 x 588 - 18K
    1920 x 982 - 252K
    You are literally creating a modeling program here. And one that operates inside of DAZ Studio which is just ridiculously awesome!
    +1
    You're so right Richard. All the comments over the years about not being able to model in DS (except with simple primitives) will soon be a thing of the past, at the rate this is developing.
    it's a bit like upholstering
    1920 x 1080 - 372K
