DAZ Hide GUI.
Blackbirdx61Blackbirdx61 Posts: 300
BTW, Is there a simple switch or setting to hide the GUI; that would be a huge help.
I did search "hide GUI" both on Goggle and the forum to no good result.
  • Richard HaseltineRichard Haseltine Posts: 109,541
    What do you mean - hide all of the panes and toolbars? You could do that by saving your current layout (Window>Workspace>Save Layout), hiding everything, saving that as a layout under a new name and then switching between the two. You can't, however, hide the main menu bar or the window title bar as far as I know.
  • MattymanxMattymanx Posts: 7,000
    If you are looking to increase how much you can see in the view port then you can simply click on the little arrows on the side of the doced panes and they should be hidden. Or do what I did and buy a widescreen monitor.
