Twosret 8
12346
  • Well, I had no intention of getting it, but the 20% off the entire cart plus the other percentages off the cart with the three addons made it basically free after adding to a big cart the other day and made everything else in the cart go down to 80% off so, now I have it. Rendering now.
    BUT, the papyrus outfit has NO textures or materials at all and everything loads just white. Is anyone else having this problem?
    Yes... me too. I've placed a ticket for that...
    Ah, good. I’m surprised no one else mentioned it.
    edited September 2020
    Here I tried mixing her with a Mousso character. I really like her skin! The dress is the Papyrus top without sleeves with the Egyptian shaders because there were no textures/materials included as mentioned above. I didn’t think I’d have much use for the outfit but it’s cool it can turn into a cute little dress. I can use the bell bottoms separately for 70’s renders lol. This is Neve hair, I didn’t even try the deforce hair because apparently it has to be fixed because there’s a problem rendering it even on 2080 tis!
    1152 x 768 - 655K
    Post edited by Wonderland on
  • memcneil70memcneil70 Posts: 5,556
    I had no issues with the Papyrus Outfit at all. When I loaded it and tried out the materials and the texture set, everything seemed to load fine and rendered okay.
  • ThyranqThyranq Posts: 589
    I didn't have any issues with the Papyrus outfit either. I had it on for this render, but opted to go with Hemet-nisut as I wanted something a bit more flashy, with a neckpiece.
    Her texture and the hd morphs are really well done!
    That’s weird. I guess I’ll have to send in a ticket...
    Redid the scene with just Twosret’s face by herself. I do really like her!
    1152 x 768 - 759K
  • Oh I love how you made it into a little dress! What a great idea! Beautiful render too wink
    Thanks! It’s fun to repurpose clothes and turn them into something other than what they were intended for laugh
  • ArtiniArtini Posts: 10,507
    Very nice - are they Twosret materials on her?
    My renders of her are coming with very dark skin at the default settings.
    Mysterious... that you have all materials and some not... but great render! wink
    Yes, it’s her skin with settings out of the box except I altered the settings on her teeth just a tiny bit because they were too yellow for my liking especially with the lighti g I was using. I used lights with a slightly warm tone and did a bit of tone mapping within DS then a SLIGHT overall tweak in Photoshop. But I didn’t change her skin setting from the default and I love her skin!
    @Wonderland, I have to apologize. You were correct.
    I went back and loaded a character then dressed her in the dForce Papyrus Dress, Pants and Sandals and they do come up in that bland greyish color. No materials were there. But when I selected the dress and and had filter by content, the main product appeared, along with the texure set. So I went to the Content Library, and there I selected the outfit, and at Connect at the top, I clicked 'Update Metadata' and then 'Install' and five more items showed up, the missing materials for the base outfit and accessories.
    I am not sure if uninstalling in DIM and reinstalling there would update the metadata that way, but I know the above method worked for me.
    Mary
    Mary
    I had uninstalled it, (through DIM) deleted the original download, redownloaded and reinstalled with the same problem. I will try updating metadata (I’m rendering now) but that should have happened automatically since I’ve restarted DS several times since. I sent in a ticket but tech support seems to take forever to respond, I have one ticket open from several months ago! I’ll have to check the zip to see if the textures are even in there!
  • I don't own any of the Twosret stuff but I have had this texture issue on other garments
    in those cases the hierarchical presets worked but not all the individual material presets
    this might be happening here
    Lovely render.
  • vwranglervwrangler Posts: 4,988
    Not really. I've downloaded the zip manually, and the /runtime/materials directory simply isn't there. I filed a ticket and got a response from support saying they were aware of the issue and working on it, and then just now got a message saying that the issue was solved and I should redownload.
    then the only explanation is at some point the files were there for some users then went missing
    its a mystery indeed cheeky
  • ZaiZai Posts: 289
    Oh hey..I like that on modern clothing!
    Ticket is solved. Update in DiM successful... materials found. That was quick. yes
    The update for the Papyrus Outfit was in DIM this morning, but it failed repeatedly at about 15% when I tried to download it on both computers. There are files, but while I am seeing morphs, I am not seeing textures, just the exact same files that were originally released. Shouldn't the material files be there?
  • JeniMorrisJeniMorris Posts: 149
    Ahmunet + Twosret ;-)
    2154 x 2800 - 4M
    Post edited by Chohole on
  • Gr00vusGr00vus Posts: 372
    Do the Twosret textures have baked in tanlines?
    Hi Jeni, I’m rendering her now and can’t get the finger paint to work. Is there some trick to it? Thanks.
    There's a geoshell for that, not sure if you saw it. If not, load that first.
     Aaaand...she's mine! LOL Couldn't resist her
    Well, there's good news and bad news - the good news is that we can stop searching for the headdress worn by Twosret 8 in the main promo....the bad news is that it was created specifically for the promo by the artist Yannek and isn't available for sale. (although maybe if they get wind of how many people are asking about it here, the artist may consider it, with a bit of luck? We can but hope) laugh
    960 x 1248 - 384K
    Ah! Thanks. Works perfectly!
    Sign me up! I LOVE those headdresses!
    It's funny, cause I just happened to have been in checking out the stuff from the bundle like 5 minutes before I saw your post. I wasn't going to use the finger paint, as I just wanted to see what the texture was like, and I just happened to catch a glimpse of the geoshell out of the corner of my eye haha
    Even said to myself "oh that comes as a geoshell" - then BAM! Question on the forums! Figured if I just kinda HAPPENED to spot it, it might have been missed by some other people laugh
