v9.0 -- mcjBuilderA - script to build anything in Daz Studio - updated sept. 16 2017
13468911
  • mCasualmCasual Posts: 4,607
    edited May 2014
    turns out it was a vertex-ordering issue
    i allowed non-vertex-ordered profile curves and i must carry them all the way through the process
    Amy taking a duckface selfie with the fixed issue F
    540 x 960 - 111K
    1920 x 1200 - 348K
    540 x 960 - 114K
    1920 x 1200 - 247K
    Post edited by mCasual on
    edited May 2014
    Friday or Saturday would be a good day to release Beta6
    which will include the "endCap" command that inserts profile shaped caps anywhere along the path
    here, 1 cap at the start of the path and one at the end
    you know when you look at this walk we get the impression the inflection point for the back of Aiko3's thigh is too low
    640 x 480 - 423K
  • RAMWolffRAMWolff Posts: 10,344
    Are those the actual poly's Casual? They look really odd to me. Do they texture well or will a tiling tile look stretched at one end and the other end as it comes together look squished?
    edited May 2014
    the method used to triangulate the polygons is called "ear clipping " it's the simplest but it does produce fine shards, the textures wont have distortions at all . the caps are not welded to the molding, else there would be issues with smoothing.
    http://en.wikipedia.org/wiki/Polygon_triangulation
    900 x 676 - 31K
    1280 x 960 - 622K
    1280 x 960 - 216K
    1280 x 960 - 221K
    Hmmm, that's extremely cool! Wonder if I can make one of those in ZBrush? Your script will create the appropriate UV too then?
    edited May 2014
    zbrush could possibly re-triangulate ( tesselate ) it using methods that produce better triangles
    but as you could see above, this doesnt cause texture layout prblems
    i was also showing that the molding sides and the endCaps can each have a separate materials
    1280 x 960 - 347K
    each cap will automatically be assigned a name based on the material for the current molding mesh ( there can be many meshes and each mesh can have more than 1 cap
    1107 x 668 - 126K
    So these are tiling tiles or done with Photoshop or similar via a UV?
    edited May 2014
    the pink ones ( used during alignment tests for the castle ) were done in paintshop the brownish ones i found by gooogling "free tilable bricks" or "free seamless bricks"
    https://www.google.ca/search?q=free+seamless+bricks&source=lnms&tbm=isch&sa=X&ei=UCxsU73qEMTNsQT1wYK4DA&ved=0CAgQ_AUoAQ&biw=1097&bih=475
    1024 x 1024 - 257K
    900 x 900 - 193K
    Well if tiles that well then color me impressed as hades eating a snow cone!
  • Miss BMiss B Posts: 3,071
    Now there's a render I wouldn't mind seeing. :coolsmirk:
    edited May 2014
    i needed a corner wall for a render ( trying to add folds to the Aiko3 bodycon )
    and badabing i had one if a few lines using mcjBuilder !
    ring
    Move 8
    hardturn 90
    Move .5
    hardturn -90
    Move .5
    hardturn -90
    Move .5
    hardturn 90
    Move 2
    hardturn 90
    Move 1
    hardturn -90
    Move 1
    hardturn 90
    Move 2
    hardturn 90
    Move .5
    hardturn -90
    Move .5
    hardturn -90
    Move .5
    hardturn 90
    Move 8
    Ring
    1920 x 1440 - 1M
    1920 x 1440 - 1M
    A MAZE INGGGGGG!
    more options for the UV map
    i'll add a "rotate UVs" which in fact swaps the Us and the Vs
    so you wont have to rotate texture images in paintshop
    along with the "invert texture x" option it covers 4 cases
    did you know you can give negative values for the daz studio surface "Tiles" ... oh you did know .. i'm just asking :)
    960 x 720 - 127K
    WOW... you really should consider making sellable stuff Casual. Your more innovative than allot of folks out there.
    the plan is, release of Beta 6 at 6PM Eastern
    things to do : make the creation of correctly UVed frames easier
    fix UVs for multi-mesh extrusions
    improve the use of Math functions ( using random() you'll be able to make more natural looking ondulations )
    expand the tutorial
    in the image below, the new "rotate UVs" option allowed me to use the stone wall texture without having to rotate it in paintshop )
    960 x 720 - 628K
    in version Beta 6, when you use the Repeat" command, you have access to a variable
    named count, which starts at 0 and increases by 1 for each repeat -
    so here we will have blocks using material mat0, mat1 and mat2
    the endCaps have the same name as the cube ( tube ) they are part of plus a suffix
    in this case mat0_cap0 mat0_Cap1, mat1_Cap0, mat1_Cap1, mat2_cap0, mat2_cap1
    1214 x 667 - 111K
    the good news is i resolved an issue ... which happened when attempting to apply a texture on a zero-tength molding
    the mildlybadbutexpected news is that the release of Beta 6 will be later in the evening instead of ... 50 minutes from now
    960 x 720 - 383K
    Your work is always the best. Glad you got more issues ironed out Casual! :-)
  • zawarkalzawarkal Posts: 1,018
    I really think this product is great and I have plans for using it on a project.
    But, I keep having problems when using it and I'm not sure why.
    I keep getting object files with the texture ribbons value 0 and nothing displays
    Is there a specific sequence of events that I need to follow.
    While testing, I load the extrusion selection on the right side of the screen and then I load a selection path on the left side of the screen.
    I press Build, Load, and Exit so I can look at the item
    But there is no item to view.
    Also, I get errors on some of the paths that are available for selecting
    such as 'type' not defined
    Help Please!! I cannot model, but I am just finding your scripts and I'm having a blast with them.
    coming up, path caps with better triangulation
    960 x 720 - 308K
    edited May 2014
    i'd need specific examples, for example, which path file you tried unsuccesfully
    also there are some settings in the profile settings panel and the path settings panel
    that are not in the path-script-file and need to be set to values that makes sense
    one way to get good settings is to use the "defaults" button
    when you press the "build" value, you must supply a filename
    and the location, then the extruded object will be created there
    ( if you do have the rights to write in that folder )
    then you can use the Load Obj button to bring it in the scene
    in the scene tab the object will have the same name as the .obj file
    maybe version Beta 6 which i'll post later will work better
    Okay, I will wait on the next version and then as I try testing it through I will make examples if my issues still exist, Thanks
    tomorrow tomorrow the new Beta 6 release estimate :)
    ( delayed because i was showing Sam Bailey x-factor videos to my sistah and there's a lot of them )
    ( i did improve the path caps ... so it can handle horizontal paths and vertucal ones
    960 x 720 - 338K
    edited May 2014
    the endcaps for some molding shapes were incomplete
    (now triangulating non-transformed vertices )
    code for this shape
    Profile gear6
    Turn 90
    endCap
    960 x 720 - 168K
    and a Happy Mothers Day !
    960 x 720 - 66K
    edited May 2014
    the daisies were made with the upcoming Beta 6 and this code
    the only advanced language command is the width of the petals which is given by
    SetScaleX 1+sin(count)
    Profile oval
    MoldSize 10 3
    Turn 90
    break
    Profile oval
    Material stem
    MoldSize 20 10
    rotateZ 90
    define petal ang
    SetRotY ang
    Ring
    repeat 5
    Move .3
    Ring
    repeatEnd
    SetScaleX 1
    Move -1.5
    defineEnd
    Material petalz
    petal 0
    petal 20
    petal 40
    petal 60
    petal 80
    petal 100
    petal 120
    petal 140
    petal 160
    petal 180
    petal 200
    petal 220
    petal 240
    petal 260
    petal 280
    petal 300
    petal 320
    petal 340
    break
    Profile quartderondIn
    Material heart
    MoldSize 33 33
    radius .0001
    turn 360
    960 x 720 - 129K
    960 x 720 - 175K
    edited May 2014
    column mounted twin candelabra built with a complex test path-script
    and using the good old mcjLathe script for the trunk
    will be posted as a prop eventually
    Profile 0_Round
    MoldSize 1 1
    Tread 10
    Radius .4
    MoveZ -0.3
    MoveY 2.1
    RotateX -90
    Ring
    Move .2
    TurnUp -180
    Move .5
    Radius .8
    TurnUp 180
    Move .02
    Ring
    setScaleX 1.1
    setScaleY 1.1
    Ring
    Move .02
    Ring
    setScaleX 4
    setScaleY 4
    Move .1
    Ring
    Move .05
    Ring
    setScaleX 8
    setScaleY 8
    Move .1
    Ring
    Move .05
    Ring
    setScaleX 2.5
    setScaleY 2.5
    Ring
    break
    Ring
    Move 1.2
    Ring
    Move 0.01
    Ring
    setScaleX 2.4
    setScaleY 2.4
    Ring
    setScaleX 0.001
    setScaleY 0.001
    Ring
    break
    setScaleX 18
    setScaleY 18
    Ring
    Move 1
    setScaleX 9
    setScaleY 9
    Ring
    break
    setScaleX 6
    setScaleY 6
    Move -0.75
    Radius 0.0001
    RotateX 90
    Turn 360
    break
    Profile square
    MoveX -0.9
    MoveY -.28
    setScaleX .33
    setScaleY .33
    Radius .9
    repeat 3
    MoldHeight 2
    Turn 120
    Break
    MoldHeight 1
    rotateY 90
    rotateX 15
    Ring
    Move 1
    Ring
    Move -1
    rotateY -90
    rotateX -15
    Break
    repeatEnd
    1920 x 1080 - 314K
    Ohhhh, nice sconce. :coolsmile:
    improved robustness of the script
    if an error in detected in your extrusion path script, processing stops, so malformed objects are not created and things like infinite loops are avoided. Note that often Daz Studio crashes when attempting to load malformed objects, so that's an important safety precaution.
    here we avoided problems the first time the script attempted to follow the script's instructions when it was building the preview image.
    then when i tried to actually build the thing
    359 x 491 - 19K
