Morph Loader Pro question
BagboyBagboy Posts: 173
Hello!
I've been trying to add a JCM to a sweater I've created for V4. I'm using DS 4.6 Pro.
After setting up the sweater and rigging it in DS, I bent V4's arm and sent Vicky and the sweater to Hexagon via the Hexagon bridge, created the morph (to fix elbow poke through, in this case), and exported just the sweater from Hexagon rather than go back through the bridge. I didn't think you could create a JCM going back through the bridge.
I go through what I believe are the proper steps for adding the JCM to the sweater through Morph Loader Pro.
But, I get this:
"Loading morph JCMrElbow...
No deltas for morph, skipping node.
Created morph successfully."
Am I missing something somewhere?
Thanks for any insights!
  • Richard HaseltineRichard Haseltine Posts: 111,382
    I've had problems with using Morph Loader pro for legacy figures - you may do better sending the OBJ back across the Bridge (go to Edit>Preferences>Interface tab>Bridges and set the option for Hexagon to Show Advanced Options, which should give you similar options to MLP - if not you can always use ERC Freze after loading the morph).
  • BagboyBagboy Posts: 173
    Thanks for the quick response, Richard! Adjusting the Hexagon Bridge settings as you described worked like a charm. Had you not pointed this out, I may have never discovered the full wonders of the Hexagon Bridge,
    Just goes to show, if something doesn't seem to be working as expected, it never hurts to ask. :-)
