M3 morphs not working in DS4.6 (solved)
WendyLuvsCatz
I bought some M3 clothes other day so decided to pimp up my M3 as autofit to genesis does not treat Armour kindly.
so bought M3 body morphs
They work in PoserPro2012 fine but not in Daz studio
parameters are there for body parts but not full body and presets like muscular 1,2 & 3 do not load
as saved muscular 3 cr2 from Poser worked in studio as did the transfer active morphs, used on this Xurge outfit
I used Texture converter to add converted M4 Buddy maps too
will be a right pain though if I must save cr2 files for every morph in Poser for studio!
just checked, works in DS3A 3.1.2.32
and
Carrara 8.5
so a DS4 issue
the morphs do show in parameters for each body bone hip downwards but not for full figure in DS4.6
I would have to adjust one slider at a time!
I tried running create EXP files exe under runtime library !Daz too
Michael 3 doesn't use ExP. Are your Poser-format content directories the same in both versions of DS, Poser and Carrara?
yes have all my Daz bought content in the same runtime installed by DIM
I seem to recall a similar issue with Millenium cat morphs but rarely use her in studio so not an issue
I need studio for the morph follower l/transfer active morphs and exporting to iClone
I may simply resort to using D|S3A if cannot solve
for non-iClone export I would just use carrara and morphing clothes using a saved Poser cr2 with all the morphs as I always did for M4 and other later figures etc
you seem to not see this issue so it cannot be a bug but something unique to my set up.
Can you go to Edit > Preferences > Content Library > Content Directory Manager in DS4, and Edit > Preferences > Directories > Content Directory Manager in DS3, and post screenshots of the Poser-format content folders?
is ok thanks all
I have it working
is under general in parameters not morphs never thought to look there
