anyone know if I can correct her 'pixelated' look?
ToobisToobis Posts: 990
edited September 2020 in The Commons
I imported her anime head from another program (pic) but she looks too blocky and pixelated :( can this be fixed in Daz at all where her face is made to be more smoother looking? or not possible.
Post edited by Toobis on
  • TaozTaoz Posts: 10,264
    If it had been all quads SubD or a Smoothing Modifier might have worked, but since it seems to contain tris also it probably won't.
    Post edited by Taoz on
  • One posibility, you can go into the surfaces tab.  If it's got the default surface shader, then towards the bottom there is a parameter called "smooth". and one below it called "angle."
    Daz defaults to smooth: on and angle: 89.9.  If angle is set to 0 or smooth is set to off, you'll get the sharp edges on the polygons like you see in your image.
  • maybe add subdivision
