Eyes (irises) in iRay.
RobinsonRobinson Posts: 751
Can someone explain iray eyes to me?  On the left is a character with standard viewport lighting and on the right I have added 4 spots and a dark grey box (we are inside the box), two front (left and right) and two rear (left and right).  As you can see, the left side eyes are colourful but on the right side the eyes are almost black.  What's going on here and more importantly, is it correct?  The eyes are from another place (Hinky's Spect-Occular Eyes 2).
Compare eyes
Post edited by Robinson on
  • The left eyes are reflecting the default HDRI image, the right eyes are in a box and if the lights are pointing towards the figure it's not a well lit box - as a result there is only a fairly dark surface to reflect (since the box is blocking the HDRI).
  • So what you're saying seems to be summed up as follows:  the lighting of the eye is highly dependent (almost totally dependent in my experiments) upon bounce lighting.  For example, they look great if the room is white, not dark grey.  Direct lighting has little to no effect, including shing a low intensity spot into the eye.  So the next question has to be how do I show iris colour in a room with dark walls. Or perhaps there's something I'm not understanding about this and that it's physically correct.
  • Sorry, I was answering the wrong question (at least on the face of it). What i said accounts for the difference in reflections and hghlights, while it may have an impact on the detail in the irises (from refraction) I think there may well be other factors at work - do you have the Maximum Path length set to a value greater than 0 in Render Settings?
  • SevrinSevrin Posts: 6,313
    edited September 2020
    There's something else going on.  This is VW Margot in a completely unreflective black box with no light reflected by anything except heself and her top, lit by the single DS spotlight she's looking at, and you can easily see the colour of her eyes.
    Maybe try different eye materials?
    500 x 650 - 146K
    Post edited by Sevrin on
  • That's just the angle of the lighting and the angle of the camera. When you take a picture as an extreme closeup, like in your op, and you use portrait lights, as you used, it will wash out the eyes. Use less light, back the camera off some or something. Also 4 lights is too much, that's why you got weird shadows.
    I strongly suggest looking into how real world photographers light portraits. It will help you light iRay tremendously.
    Max path length is -1.  I assume that means "let iRay decide".
    I'm not so sure really.  I have key, fill and so on, and this is an experimental portrait setup (4 lights is fine).  I tried with one light at various angles and I get a similar effect, even with the luminosity dialled back and the light very close to the eye.  I'm going to try with an emissive light from a plane and see if that makes a difference.
    Yes
  • Same lighting in both (but only one front spot this time), left is Brooklyn HD eye material and right is Hinky's.  Brooklyn HD eyes are very flat with no highlights (hence my desire to use some better materials).  Hinky's are very dark again but have some nice highlights.  Perhaps a little glassy.  Must be something up with the shader.  I mean Hinky's look great when you have a lot of bounce lighting in the scene from all directions.  Not sure where to start looking at the settings though.
    In order to track down the culprit, try setting Cutout Opacity to zero for Cornea and EyeMoisture and if the blackness goes away, try one by one to pinpoint it.
    I had some problem with unusual reflections in the Iris that didn't go away and found the problem in Cornea settings.
  • In the end I used eyes from another figure, as suggested above!  No time to spend on fixing the problem with this specific eye product, though I may return to it.
  • I've had this exact same problem with certain characters. I forget what it is, but I do recall that in order to correct the problem, I loaded a 2nd character into the scene that did not have the problem and it was a simple matter of changing 1 or 2 surface settings. What appears to be happening is the pixels on the irises don't seem to be converging enough(kind of like what happens when knuckleheads add a little refractive index weight to the teeth). So I would try looking at those settings and compare them to a different character. Chances are, the refractive index settings for the water layer covering the irises is wrong and/or something in the glossy settings. Just a guess.
