Question about bulge on sides of chest (Gen and Gen2 female)
AnimAnim Posts: 241
Hi,
I am new to DS and started using Genesis and Genesis 2.
Now I have a question about the chest.
The side of the chest looks strange to me, if the arms are fully down (happens with Gen2 female and Gen1 male and female). It is difficult to explain as non native speaker but it looks like the side of the chest is some kind of bow.
I added a screenshot to show what I mean (breast reduced to check that's not caused by them).
I tried to compensate with:
- Genesis2FemaleBodyMorphs
- ShapeShiftforGenesis2Female
- Genesis2FemaleBodyMorphResourceKit
- Genesis2FemaleMixedMorphResourceKit
- and a bunch of free ones I found on shareCG.
But nothing helps.
Is this normal for the Genesis figures and can't be changed?
Thanks for help.
[EDIT]
I made another screenshot ffrom a back view. It is more obvious, what I mean in that one.
In both geometries the bulge is present (but the area where the arm meets the shoulder, looks human on Gen1 but very strange on Gen2).
Did I do something wrong with installing or loading the figures?
I used InstallManager to install them and loaded them with doubleclick from the content library.
Is it required to buy something like Victoria 6 because Genesis Base is what the name indicates, a Base?
Sorry if this sound very noob. Indeed I am one with DS.
Post edited by Anim on
  • info_7ab70978f3info_7ab70978f3 Posts: 78
    Those are her/it's andro-morph lats
  • BejaymacBejaymac Posts: 1,942
    Unfortunately you haven't done anything wrong, that really is how bad the armpits on those figures are.
    Somewhere in DS4 there is a hidden mesh smoothing or something similar, this is what's causing the problem, you can see it at work if you hold onto a slider, if you then let it go you will notice the mesh changes shape as the smoothing kicks in.
