When I load my character the Hair loads between the characters feet.
When I load my character the Hair loads between the characters feet in Unreal.
How do i fix this.
The character was Genesis 2.
JD
How do i fix this.
JD
Is the hair a parented prop or a fitted figure?
I fitted it to the figure. Meaning under edit I said "fit to Gen 2 Female".
Was it originally made for Genesis 2 Female?
Yep.
PyritHair...by SWAM...The Genesis 2 version...not the V4 version, not the Genesis version...
Most likely the hair isn't attached to the character. You might need to right click and "Fit-To" the character. This might work as well. http://davidvodhanel.com/daz-to-unreal-fixing-accessories-that-dont-animate-with-the-character/
If not let me know and I'll see if I can try that one.
If you look above, I did fit the hair to the character...But I will try it again....
