Breaking Waves- Only Shaders And Light? **SOLVED**
NovicaNovica Posts: 23,925
edited May 2014 in The Commons
http://www.daz3d.com/breaking-waves
It says this is included, but I only have a light set, and two shaders. Anyone else have this that can see if they have the pp2, daz or obj? I reinstalled it again, same thing.
What's included:
Morphing Ocean Wave/Curls Prop (.PP2, .DAZ, .OBJ )
Light Blocking Apron
Textures Include:
Breaking Wave Water Texture (4096 x 4096 )
Breaking Water Plane - Displacement (1600 x 1600 )
Post edited by Novica on
    edited April 2014
    There are 2 versions you get. Breaking Waves DS and Breaking Waves PS.
    The pp2 for the PS version is in Poser Format > Library > Props > FirstBastion > BreakingWaves
    The .daz for the DS version is in Daz Studio Format > Library > Environments > First_Bastion > BreakingWaves
    Post edited by Lissa_xyz on
  • NovicaNovica Posts: 23,925
    Thanks, I am able to find the product. What I am saying is there are only two shaders and a light. There is no obj / static prop to apply them to.
    edited April 2014
    The waves themselves should be in the actual BreakingWaves folder, not a subfolder. If they're not there, try completely removing and redownloading.
    594 x 1080 - 236K
    This is what I have. :)
    1200 x 677 - 71K
    edited April 2014
    Well, that's weird. That is what I get from the Products click, which has always had the entire thing. Going the Environments route, I get something different, and it does not have the shaders, etc. Strange.
    EDIT: Yes, it does, never mind :) I scrolled over and expanded the menu.
    Thanks for the help.
    edited April 2014
    Np. Sorry I guess I should've elaborated to use the content library. I never use smart content so I didn't think of it. :red:
    No, you were right- and I WAS using Content Library (Products.) I wasn't clear. Anyway I'll mark as solved, but folks may want to be aware that if you use Products in Content Library, you are not getting the full product. I have never had that happen before. Makes me wonder though if I am missing some files from other products and I don't know it.
    edited May 2014
    Products view requires CMS to be on (the daz studio format/poser format parts don't), which means it most likely works off of the metadata. Chances are the waves themselves aren't flagged properly if at all.
  • SyphonapteraSyphonaptera Posts: 191
    I had the same problem here.
    and I had troubles over and over again with orders earlier , because , f.e. , either it was not mentioned the product was not compatible with a certain DAZ version or the product not being compatible became a known issue.
    Concerning Breaking Waves; I also could not find any .obj to load or .duf / .daz , neither in the Smart Content , no where....I also just saw these 3 files
    Why doesn't the vendor notify us where , what and how something works?
    I am getting so pissed of , at every order I pay and download there is always at least ONE product not working or with missing files or I have to search more info at the forum and wrestle my way through folders to find what I think is missing......
    Sincerely
    Mr NOT amused.....
  • frank0314frank0314 Posts: 14,743
    The readme tells you most of the time where the files are located for a product. If using DIM then clircle on the ! and in the product library then look up the sku in the documentation center. Also, if in DIM you can right click on teh file and select "Show Installed Files"
    No go.
    Page not found on file list, or at top in old wiki.
    http://docs.daz3d.com/doku.php/public/read_me/index/14576/start
    Here's the right click in DIM, showing Environment as location.
    1398 x 1310 - 2M
