Asobi Texture problem
http://i863.photobucket.com/albums/ab193/philipnova798/Aso.png
I think the picture in the link gives an adequate explanation as to what's going on (the grey bits on the armpits, fingers, inner thighs and feet, which are not shown). Which leads me to ask - what the hell is going on and/or what am I doing wrong here?
  • fixmypcmikefixmypcmike Posts: 19,692
    I can't see you image -- do you have V5, and did you check that the V5 UVset is being used?
    edited April 2014
    It looks like you have the wrong UV Map selected for the figure you are using.
    Go to the Surfaces pane, and look for the UV Set area, and make sure that you have the correct figures UV Map selected.
    What figure is it, and what skin do you have applied?
    EDIT;
    XPost Mike
    Post edited by JimmyC_2009 on
  • edited December 1969
    Well I have no idea how to insert an image. And no, I don't have V5, just the base Genesis figure.
    As for the textures, I'm just using the default Asobi textures. And I have checked, they're in the proper spots.
    Victoria 5 is required for Asobi, as it used the V5 UVset.
  • ZilvergrafixZilvergrafix Posts: 1,385
    Philmister978, you should check the requirements when you bought Asobi, ´the Asobi default texture forcefully needs the UV setting on Victoria 5 in order to being displayed properly.
    1523 x 935 - 152K
    809 x 662 - 72K
