Rigging and Weight Mapping
Hoplite490Hoplite490 Posts: 111
I seem to have a problem with bones not manipulating the mesh of an object. I been through tutorials and YouTube videos but do not get the same results. Here is what I do:
Model of SCAR H assault rifle created in 3ds Max 2013 64bit. Model is made up 7 objects.
1. I export the model as an .obj from Max using the default preset for DAZ Studio.
2. Within Daz, I open the Figure Setup and add the geometry to the Geometry List then drag it over to the Relationships pane.
3. I create the parent child relationships. For Example, the stock is two pieces, the first hinges from the trigger housing and the second telescopes into the first. Trigger Housing -> First Stock ->Second Stock.
4. I set the Axis then Select Weight Maps.
5. Created asTriAx Weighted figure.
5. With the Joint Editor, I manipulate the bones to work with the model. The hinged stock is angled, so when rotated, it rotates at a slight angle.
6. Memorize the Figure Rigging.
7. When I use the Weight Map Brush, I select by Surfaces and apply 100%. At first I assigned the selection to just the axis that I would need but then tried to assign to all axis as well as scale. same result.
8. What I have is a rigged rifle that has been weight mapped but if I select the hinged stock, none of the Transforms work.
I do not know what I am doing wrong. I am obviously skipping a step.
  • Richard HaseltineRichard Haseltine Posts: 109,546
    Nothing is leaping out at me as an issue.Exactly which version of DS are you suing? Please post a screenshot showing the Tool Settings pane and the model with the bone that's meant to move selected and the Node Weight Brush Tool active.
  • Hoplite490Hoplite490 Posts: 111
    For the last pic, weight map brush, the pieces are rigid so I select by face groups and fill the entire face 100%
    767 x 886 - 203K
    566 x 593 - 152K
    1440 x 900 - 305K
    808 x 565 - 164K
