Installing plugins
WaterBaron
When I was installing Daz, and all of its little things in the startup menu, I think I messed up on the plugins and made a custom directory so I can't find the option to use Zbrush. What is the plugin's default folder location or common path if that is what it is called? Also, a file didn't download correctly while I was installing Gen2 starter essentials so I want able to complete a part of the tutorial lesson. Any advice is much appreciated!
The Daz side will go to the Daz Studio folder, and should appear in the File menu. The ZBrush path needs to be set for the application, though in fact most of the files go in a common folder in the Public profile. Have you entered your serial number for DS? Have you tried running Window>Workspace>Update and Merge Menus?
