Where find Daz Studio render settings 8 bit 16 bit
Have been looking at the info in the tab for render settings for Daz Studio. Where can I find bit information for the image? Is it possible to choose 8 bit, 16 bit?
Post edited by Diomede on
I don't think that is possible, but if you go to the advanced tab > canvases and add a beauty canvas, once your render is done and you save it it will create a folder with the same name +_canvases
and you will find a 32 bit .exr version of your render in there
jpg and png are only 8 bit as far as I can tell.
You could use the exr and photoshop/gimp to output to a 16bit jpeg/png
Thanks
Whilst I think about it, don't compress the jpg due to its lossy nature; in other words, compressing jpg means they loose information.
Yes, the best options for saving a render are the non-lossy .png and .tif (I always use .tif). After I've used postwork to add titles, credits, etc. then I do a final save as .jpg.
I've found the easiest method to recreate old-school style 3D renders is to just render it normally and then use compression filters to give it a 90s look if that's what you're after.
