v9.0 -- mcjBuilderA - script to build anything in Daz Studio - updated sept. 16 2017
1235711
  • mCasualmCasual Posts: 4,607
    RAMWolff said:
    Got it... now one other request. Is it possible to have the manual in a downloadable PDF?
    my mcasualsdazscripts3 is quite full in fact i had to delete the mcjBox pdf manual and a few images
    to have space for the mcjBuilderA manual updates
    for now i converted the manual .... which is not completed --- it's a 10 MB PDF and i placed it here
    https://sites.google.com/site/mcasualsdazscripts4/bric-a-brac/mcjBuilderABeta3_manual.pdf?attredirects=0&d=1
    the final manual will probably be more compact, like 5 MB and will be on mcjBuilderA's page ... someday :)
    1280 x 720 - 87K
  • Miss BMiss B Posts: 3,071
    edited April 2014
    I was JUST thinking the same thing Richard. Thanks for asking.
    Thank you kind sir. :coolsmile: This makes things easier for working off-lline.
    Post edited by Miss B on
  • RAMWolffRAMWolff Posts: 10,347
    Oh, thanks so much . I think then I'll just hold off for the full final of this. :-)
  • 3WC3WC Posts: 1,142
    edited April 2014
    For some reason this is all I get:
    Log file says:
    Executing DAZ Script file: C:/Users/Wes/Documents/DAZ 3D/Studio/My Library/Scripts/mcasual/mcjBuilderA.dsa
    WARNING: Script Error: Line 2307
    WARNING: SyntaxError: Parse error
    WARNING: Stack Trace:
    ()@:2307
    Error in script execution!
    Using Windows 7 64 bit
    DS 4.6.2.120 64bit
    422 x 109 - 12K
    Post edited by 3WC on
    edited April 2014
    see below
    Post edited by mCasual on
    Log file says:
    ()@:2307
    DS 4.6.2.120 64bit
    sorry !!
    it’s a tiny bug affecting only paths that include the “closePath” command and i didn’t use this recently
    in the image shown below you can see line 2307 which was mentioned in your error message
    you could use notepad/wordpad to change the ’ character with the ; character
    but ... 5 or 10 minutes from now i’ll post the corrected version as version “Beta 4” on mcjBluilderA’s web page
    the new version will also include the “square” extrusion path which is the default extrusion path -
    the first time you start mcjBuilderA it must search for it and be worried
    Image Attachments
    858 x 312 - 40K
    the 84 moldings / extrusion profiles
    one could print them
    though one could also simply save it to disk
    908 x 557 - 58K
    908 x 557 - 60K
    908 x 557 - 58K
    edited April 2014
    Thanks for the update, but I'm still getting an error, this time:
    WARNING: Script Error: Line 1785
    WARNING: TypeError: Result of expression 'extrusionPathCurves[0]' [undefined] is not an object.
    ()@:1785
    I opened it up in Notepad, but I have no idea what's wrong now.
    1785 var n = extrusionPathCurves[0].length;
    EDIT:
    Okay, I just deleted the ".length", but then I got another error in 1787, which seemed to be fixed by changing "o" to "0", now I'm getting this:
    WARNING: Script Error: Line 1791
    WARNING: TypeError: Result of expression 'edges' [undefined] is not an object.
    ()@:1791
    1791 var p0 = extrusionPathVertices[edges[0]];
    the manual for mcjBuilderA Beta4 in PDF format, only 2 megs is right here
    https://sites.google.com/site/mcasualsdazscripts3/mcjbuildera/mcjBuilderA_Beta4_Manual.pdf?attredirects=0&d=1
    edited April 2014
    ()@:1785
    EDIT:
    ()@:1791
    sorry again
    you are probably trying to open an extrusion-path file which is in .obj format
    unfortunately ( yeah lets blame Fortune ) that's another option i didn't test recently and it's bugged !
    you could replace the code with
    function objPathToScriptedPathpath()
     var edges = extrusionPathCurves[0];
     var bClosePath = wchkClosePath.checked;
    this should at least prevent the mcjBuilder from halting
    then you should only load path files in .txt format from the mcjBuilder\paths\txt folder
    or write one
    later today i'll fix the script so it can handle .obj paths correctly
    that version will be named Beta 5
    not far from there is a line that reads
    wLog.append( "Move\t" + shorter( d ) + "\t" + "0" );
    changing it to this would improve things to
    wLog.append( "Move\t" + shorter( d ) );
    wwes said:
    ... but I'm still getting an error, ...
    Beta 5 will be posted in the next 5 minutes !
    1446 x 792 - 118K
    * * mcjBuilderA Beta 5 ** * * mcjBuilderA Beta 5 ** * * mcjBuilderA Beta 5 **
    fixed the issue with extrusion path scripts that were Loaded/Imported in .obj format
    same bat time same bat site --> https://sites.google.com/site/mcasualsdazscripts3/mcjbuildera
    444 x 444 - 72K
    edited April 2014
    Casual said:
    sorry again
    Well, I don't know what I'm trying, because these errors stop the script from even loading. It's not just halting, it's not starting in the first place. Just tried Beta 5, am getting the same thing, script won't start up. I haven't checked the log file to see yet what the problem is.
    Thanks for your hard work, this looks like an awesome script, I just can't get it to work for me.
    EDIT: Ok, I deleted the entire mcjbuildera folder, then reinstalled the new beta 5, now it seems to work.
    yay!
    if someday the script stops working, and if you are acquainted with regedit
    you could delete the registry section for mcjBuilderA
    which is something like HKEY_USERS\ ... \Software\DAZ\Studio3\mcjBuilderA
    down the road i'll improve things :)
    I have to find time to play with this! I have to find time . . . I have to . . .
    OK I downloaded Beta5, and REALLY need to find time to play with this. :coolsmile:
    edited May 2014
    next version ( Beta 6 ) will have mathematical operators ( + - * / being the most used )
    here it was used to set the position of the corner of the frame, based on the size of the frame
    ( - width/2 , height /2 )
    closePath false
    profileUnits inches
    moldSize 1 1
    pathUnits feet
    tread 1
    define cadre w h
    moveto -w/2 0 h/2
    hardturn 90
    move w
    hardturn 90
    move h
    hardturn 90
    move w
    hardturn 90
    move h
    hardturn 90
    defineEnd
    cadre 4 2.25
    also the next version will stop trying to re-load the last saved path file on startup to reduce possibilities you get stuck!
    instead it will always start with the path script for a frame
    other mathematical functions like random() and sin() will let us do some pretty fancy stuff !! to be continued
    1920 x 1200 - 257K
    edited May 2014
    ( feature for the upcoming Beta 6 )
    here you see a path script using the sine function and the "fr" variable to modulate the X and Z position of the extrusion nozzle
    "fr" variable means "frame" its increases as the extrusion progresses , 1 frame per "ring".
    you will also have access to the current extrusion path length
    define segment
    MoveTo sin(10*fr*180/pi) 0 fr/3
    Ring
    defineEnd
    repeat 100
    segment
    repeatEnd
    1920 x 1200 - 391K
  • IndigoJansonIndigoJanson Posts: 1,100
    What can I say... just took this for a test drive (with your manual at my side) and it's great! Very hand script for quickly building this kind of thing and shaders went on nicely too.
    I've only done simple rectangular frames so far but looking forward to exploring further.
    Thank you for making it and sharing with us. :)
    thanks for testing it ! you were brave :)
    edited May 2014
    Casual said:
    you were brave :)
    Only in that I'm cautious about downloading and installing scripts... but one look at your avatar and I knew that was a face I could trust. ;)
    I will need to spend some time with this, right now I'm having trouble going beyond the rectangular and square frames (though that alone is a nice feature and textures go on beautifully). I'm sure the problem is between the monitor and chair (i.e. I've typed in an odd value somewhere), as your code looks self-explanatory and the manual makes sense.
    [EDIT: Yes, I was missing something obvious... I'm making progress now.]
    I've been learning to use Blender but this is a great time-saver and I love that I'll be able to add my own path scripts too.
    Just to prove that it's possible to get results right from the start, I roped in my ever-willing assistant to pose for this image. The frame uses a Gemologica tile (1 horizontal, 10 vertical gives me the best results).
    494 x 494 - 392K
    Post edited by IndigoJanson on
    edited May 2014
    in version Beta 6, there will be a variable named rcpt ( meaning repeat-counter ) which will increase by 1 each time a "repeat" is used
    so in the example below, i used this variable to position each arch
    The columns were also made using mcjBuilder Beta6
    ( see "TAHITI Love Sick M/V" for the real life columns and arches )
     define arche x
    profile classic_ovolo
    StepAngle 11.25
    radius 1.5
    MoveTo x+.5 5 .5
    MoldSize 35 35
    setRot 0 90 90
    TurnUp 180
    break
    defineEnd
    define arch x
    profile square
    StepAngle 11.25
    radius 1.325
    MoveTo x+.675 5 -.25
    MoldSize 150 35
    setRot 0 90 90
    TurnUp 180
    break
    defineEnd
    repeat 4
    arche 4*grcpt-8
    arch 4*grcpt-8
    repeatEnd
    figure 2 - Beta 6 will possibly include the ability to make complex path-caps ( the upper wall )
    1920 x 1299 - 560K
    1280 x 720 - 168K
    a short tutorial that can help you figure how to proceed when writing your extrusion path scripts
    i tried to concentrate on the essentials
    https://sites.google.com/site/mcasualsdazscripts4/mcjbuilteratutorial1
    800 x 450 - 34K
    Thank you sir. Those arches look wonderful!! :coolsmile:
    edited May 2014
    thanks they'll be packaged with the next version as path files and maybe as props too
    maybe the tutorial will be extended to cover them ( which was the plan but /// time you know )
    1920 x 1080 - 765K
    1920 x 1200 - 341K
    edited May 2014
    mcjSuperLathe which is similar to mcjBuilder
    had "cutouts" or "lids" so mcjBuilder Beta 6 will have them too
    http://www.daz3d.com/forums/discussion/1785/P30
    so you'll have handrails with closed ends
    or guitars
    the "ear-cutting" triangulation code comes from Bill Overman
    // http://www.codeplex.com/PolygonTriangulation
    600 x 600 - 59K
    600 x 600 - 115K
    Very cool Casual!
    It's definitely getting better and better. :coolsmile:
    edited May 2014
    works ! kinda but the UVs on the floor are not ok yet
    1920 x 1080 - 236K
    1600 x 900 - 1M
    Excited at the way this continues to progress! Thanks for the tutorial, I must grab that although might be a few days before I can work through it.
    edited May 2014
    oops incomplete triangulation
    guess i was lucky in a way, the test case revealed a rarely occurring problem
    1920 x 1200 - 829K
    1920 x 1080 - 291K
    1920 x 1080 - 176K
