DIM login issues?
SimonJMSimonJM Posts: 6,084
Just me or are others not able to login/connect with DIM?
Hold on ... just looking at DIM (in offline mode) and it looks like my email has been overwritten by account name ... wth???
And there is no way for me to edit the data!
Post edited by SimonJM on
  • JaderailJaderail Posts: 0
    Gear, Accounts. Add a new one and remove the bad one.
    642 x 543 - 54K
  • SimonJMSimonJM Posts: 6,084
    That's what I ended up doing - and ... well, I didn't have to delete the old account as the 'old' one and the new one sort of merged and I ended up with just a single account. Which, I am glad to say, seems to work :)
    As long as your happy I'm happy. :)
    Happy it's back working, not so happy about why it went Tango Uniform - mainly as I do not have a clue!
    Bad ram write at last close... HD hicup at last close, bad read on open last open causing a bad save on exit. The things we call PC's are good but they do have errors from time to time just for no reason. Even a small surge in power or drop in power can cause odd things and we as users never see the cause. If everything worked right all the time why do I have all these backups? ;-P
    I did have an 'issue' with DS locking up, which also caused PC to lockup which necessitated a power-off. On restart my DS had lost all it's customisation and had reset to default workspace and style. That I can understand, sort of. But DIM was not open at the time.
    I meant last DIM use. As in something unseen as a PC user happened. It does happen on rare occasions. I'm glad they are so rare.
    Last DIM use before it all went 'orribly wrong was fine. Since then I have noticed that it junked all my settings, so I had to re-add all target install locations and application directories ... joy! :)
