Morph Loader Pro always failing (Geometry not matching despite it's the same)
Hello,
I'm loading Genesis8 female and exporting an OBJ.
Then I'm immediately importing it again with Morph Loader Pro and it's failing "Geometry does not match".
Actually I wanted of course to sculpt on the OBJ outside a blend shape, but this even doesn't work with the original file.
What's wrong here, what is the reason?
Thanks
(DAZ Studio 4.12 Pro)
Delete the eyelashes, set figure to base geometry instead of high resolution, then export.
A few things to note, if you have it load the genesis 8 female dev load instead, otherwise make sure you hide the eyelashes and set the genesis 8 female to base resolution and not subD before you export as .obj
if you use blender for your sculpting later make sure that you tick the option in the blender import "keep vertex order" as well
