keycodes no longer working in daz {resolved}
WillowRaven
some basic keycodes like ctrl/s for is no longer going anything in daz ... neither is ctrl/z or y for undo/redo ... is it just me?
Post edited by WillowRaven on
Try reloading your layout.
I've restarted the computer several times since this started a few days ago.
@WillowRaven
No issues for me. I realize this may noy be helpful.
What version of DS are you using?
Did you reload your layout?
I'm using 4.11 an I reloaded not only that scene but other scenes and started new scenes ... none of my key commands work anymore.
Window > Workspace > Load Layout
Not sure how or why that worked, but thanks, Fixmypcmike :)
_ is there a Custom key assignments ?? _ If so, reset to default _Not sure if there is
Reloading the layout will reset the short cuts. You can also load only a specofoc aspect from the Window>Workspace>Customise dialogue, or right-click on a command in the elft-hand column in that dialogue and select the option to reset its shorcut.
