what does this figure loading error mean
i just spent days reinstalling all the files i could find into the "My Daz 3D Library" directory.
but while trying to load Genesis1 figures i get this error , when i select "ok" it loads up anyway.....
but will it function properly ?
and where do i get the "log file" that it refers to :
Post edited by downhillpony_b0c397dc36 on
  • Design Anvil - Razor42Design Anvil - Razor42 Posts: 1,250
    Generallythis issue is in regards to issues with morphs for the figure.
    Most times if genesis is loading fine it can be ignored, but may be an indication something not quite correctly installed.
    After you encounter the error go to HELP/TROUBLESHOOTING/VIEWLOG
    Take a copy of any warning or errors and paste them here.
  • Richard HaseltineRichard Haseltine Posts: 109,284
    That's a very old issue, that should have been fixed on all affected content long since. As Razor 42 says, check the log file to see exactly which files are causing the problem.
  • edited December 1969
    hey guys thanks for the input ..
    but i got frustrated and wiped the whole library ..... and reinstalled DS 4.62
    a lot of my stuff is old , or 3rd party installers , that you have to tell what to do...
    which half the time i'm not really sure.
    the DZIM will install everything from my Daz account and stick it all where it goes...
    is there any way i can have the DZIM install other stuff too ?
    i know it stores all the downloaded files in a public folder .....
    could i put 3rd party stuff in that folder and fire up DZIM and have it run them too ?
    probably not .... but i might try it anyway .... nothing to lose ...
    DIM can only use DAZ 3D products, as it needs access to your order history and Product library in order to do what it does.
    3rd party content has to be installed manually I am afraid.
    yeah , that's what i thought .....
    oh well , i will just have to be very careful where i put stuff this time.
