Sabertooth Reloaded and LAMH issues
nDelphinDelphi Posts: 1,934
OK, these are separate issues.
1) The LAMH player crashes DAZ Studio 4.6 if I attach a hair preset the second time around, that is after I delete a hair preset after attaching it (this happens with any model, be it the Wolf, Sabertooth, etc.). DAZ Studio just crashes, no error message and no log entry of the issue whatsoever. I do have a log entry of a first attach.
Importing File...
Importing SaberTooth - Daz - no fur.cr2 ...
Reading AMSBT_body_0.obj
PZ3Importer: Removing face group default no associated node.
Time to load file: 528.889 ms
Imported: SaberTooth - Daz - no fur.cr2
Building Scene...
File loaded in 0 min 1.4 sec.
Loaded file: SaberTooth - Daz - no fur.cr2
Ran tdlmake on image G:/My DAZ 3D Library/Runtime/Textures/AM/Felidae/Smilodon Fatalis/AMSBT_body.jpg
WARNING: elements\dznode.cpp(2120): NULL child pointer passed to DzNode::addNodeChild()
WARNING: Could not parse stylesheet of widget 0xac16db0
WARNING: Object::connect: No such slot lookAtMyHairViewToolAction::adjustPosition2() in afirstpluginaction.cpp:2230
WARNING: Object::connect: (sender name: 'AMSBT_body_0_42630')
WARNING: Object::connect: (receiver name: 'CreateItemAction')
WARNING: Object::connect: No such slot lookAtMyHairViewToolAction::transformTimeout() in afirstpluginaction.cpp:2307
Compiled C:/Users/[account]/AppData/Roaming/DAZ 3D/Studio4/shaders/brickyard/{597e76fe-22a8-4ab5-b63e-82b44d41cb21}/shader_Surface.sdl...
2) I downloaded LAMH Ice Age Pack but after attaching the hair preset to the SaberTooth the hair cover the eyes and also the quantity of the hair seems to be small at 10,000, it doesn't look right when rendered. The hair presets for the Wolf and Moose work and render just fine.
  • Kendall SearsKendall Sears Posts: 2,995
    Make sure that you have the latest free player.
    The hair quantity can be changed using the free player's pane. 10000 hairs is quite few.
    Kendall
  • nDelphinDelphi Posts: 1,934
    edited April 2014
    Yes, I install everything thru DIM.
    I know, but the hair still covers the eyes, I have no idea how to change that. I am hoping there is a fix and AM can chime in here and let me/us know?
    Post edited by nDelphi on
  • Alessandro MastronardiAlessandro Mastronardi Posts: 2,652
    Hi, I think there might be an issue with the Sabertooth LAMH fur preset, let me check tomorrow what I can do. IF it doesn't work I'll make a new one...
