A call to GenX2 and AddOn for Genesis 3 owners. I need a favor.
Hello, can someone who has these two addons help me?
I'm trying to have only one male and female model in G3, like in G1. For this, it occurred to me to transfer the "Basic Female" morph from G1 to the G3M model. In this way, the G3M would have a morph that makes it a female model.
Both addons cost too much money to test without knowing how the results will be. So could someone take the test and share images, gifs or a video of the result? It would even be perfect if you transfer other G1 morphs and test them in G3M all together, especially with "Basic female" active to check that it really works well.
Thank you very much for reading me, I hope that some kind soul can help. smiley
  • 3Diva3Diva Posts: 12,017
    edited August 2020
    Basic Female for Genesis isn't very feminine, imo, so you're not going to get a super feminine look by transferring it to Genesis 3 Male, imo.
    Here's the transfer. This is Genesis 3 Male with just Genesis Base Female morph dialled in:
    Here's Genesis 3 Male with the Genesis Base Female morph + the default Genesis Shape dialled in:
    The skin mats in the renders are from FWSA Max for Tween Ryan. https://www.daz3d.com/fwsa-max-for-tween-ryan-7
    1000 x 1300 - 1006K
    1000 x 1300 - 997K
    Post edited by 3Diva on
  • dmputadmputa Posts: 36
    Thank you very much 3Diva, you rock! laugh
    The second image is using "basic female" and "basic female head" morphs, right?
    The first image is true that it isn't very feminine, but the second image is much better. Surely with another texture it would be even better. There are also other female morphs in addons for G1 and G3F that could be used to make it look more feminine, I think.
    Thank you very much again. smiley
    If you or someone else wants to share more images they are welcome to see how I could achieve the best results. cheeky
  • Phoenix1966Phoenix1966 Posts: 1,901
    edited August 2020
    Why not this product? And with this UV swap product, you can then use G8F skins as well. And there is also this freebie by @agentunawares to try out.
    Here's the freebie results:
    Here's the G3 Cross-Figure Resource Kit used:
    927 x 1500 - 677K
    927 x 1500 - 684K
    Post edited by Phoenix1966 on
    Yes, I found the agentunawares addon recently. It's a possible solution. I've been testing it and the G3M morph from male to female is better than G3F from female to male, in my opinion.
    The Genesis 3 Cross-Figure Resource Kit is just for adjusting clothes, right?
    Thanks a lot for the help, Phoenix1966. You are also great. laugh
