Orc HD issue
Please can someone help me? I have an issue with  the Orc HD,
In the view port the model looks fine.
But when I export it or while I'm changing a morph ex body size, the model is changing, losing all the detailed striations. I think fitness and muscular details, not sure. Please check the image.
After I release the morphs scroll bar the details reappear, but on the export I couldn't find anything to fix this.
Anyone knows why it has this behaviour and how to fix it?
  • GordigGordig Posts: 10,626
    The reason it's changing in the viewport when you adjust morphs is because the HD details are being applied on top of everything else. How are you exporting?
  • anepheranepher Posts: 144
    edited August 2020
    FBX 2012 binary
    I'm attaching an image with the configuration and morphs.
    At export time it is changing the same way as when changing a morph.
    1681 x 678 - 258K
    Post edited by anepher on
    Try exporting with "subD information" checked.
    Actually, I just tried that, and FBX doesn't preserve subD. OBJ does, though, for whatever that's worth.
    Indeed, I tried myself and looked for workarounds, seems there are none for FBX. Only exporting with OBJ is possible. Thank you for your time and help.
