Adding to Cart…
The disc errors are from well before the stormy daya, and other issues. The numbers seem to start 5 or 6 up to 13, sometimes skipping one, while the physical drives go from 0 to 4 - so that doesn't look like the errors are the physical drives if they count the same way. Only the boot drive has partitions. I did install the XBox app, in very late June (last chance to sign up for three free months that came with the CPU,) so - although I think there are a few days between installation and start of the blocks of disc errors - that may well be it.
The ethernet cable from the router to the PC goes through the UPS, and the phone line into the router has a passive surge protector too. I did, many years ago now, lose a router and one of the network ports on the PC to a nearby strike - that PC is otherwise still working I think.
Yes, it has a back-up BIOS. I was a little wary of doing anything to the BIOS while there are doubts over stability. The only powered devices connected are speakers (audio jack - they are really old) and the monitor (USB hub). Other than those it's just keybpard, mouse, and Wacom tablet.
I'll have to check - I have had SMART monitoring in the past but not sure it's on this system. (I don't see the Seagate folder in All programmes so probably needs adding back - though it does sound as if the disc errors may be a red herring.)
Seatools seems to give the SMART OK, SFC said it found and repaired some corrupt files but I can't figure out which from the log it produced - searching for Repair produces lots of lines about verify and repair service but they don't seem tied to a particular module.
I had a LED TV ruined somehow from an electrical surge. The house itself wasn't directly struck & the TV and all devices were on surge protectors but apparently the amount of voltage that surge protector let through was still enough to ruin the TV. I guess there might of technically been a huge inductance on the antenna wire without a lightning strike that could of caused it although I've never read of such a thing.
If a computer was on a UPS though and only it, then that wouldn't be a possibility I'm pretty sure.
My current house has primitive non-code standard electrical wiring so I guess everything in my house is a risk. We've had a transformer station within 2 miles get blown in the last 2 year too. I thought it had blown up my monitor as it refused to work for a week but duh, the video cable came loose on me, coincidently at the same time.
Lopsing a TV through the antenna is very possible. An antenna is basically just a big lightning rod. If you DIY your own TV antenna you need to include what is called a lightning arrester in the line. It's should divert static into ground. Just follow the instructions that come with it (your cable company should have something similar in the line leading to your modem as well).
I'm not sure if anyone already suggested this, but have you searched for 0x000000be. I've done that when I've gotten one of those and found information to tell me what the issue was. Some times it tells you what file is causing the issue on the BSOD. Sometimes it's hard to spot it even when it's there. But in the example sited in the link below, there was no file listed.
I found this website that has some things you try
Note: I'm not sure if you are allowed to post a link, so I edited my post. I searched for 0x000000be and the first one started with...
neosmart.net/wiki/0x000000
if you want to.
If you have a Dell computer, they have a program called Dell Update which will tell you which drives need updated. Other brands might have a program like that too. You can also go to the manufacters website and look up you pc and check the drivers again the ones you have.
Modern TVs are quite sensitive items, they are basically computers. This stuff happens a lot. A surge can get through anything that is connected, not just the power. You can get surges through your signal as well as Ethernet. I've seen Ethernet ports with burn marks on them, but a lot of times you do not see any clear signs of damage. If you know which part failed, that may point to the cause. If the power board board failed, it was likely through the power, if the main board failed it more likely came through a connected device. A lot of times it seems like the connected devices are fine...they just pass the surge through. But sometimes the devices get disabled, or the HDMI ports fail. The device (or TV) may be fine otherwise.
Most people don't think to place their the signal on protection. Antennas and satellite dishes are literal lightening rods and can easily pass electricity through. It doesn't have to be a direct strike. The air can be quite charged without us being able to see a visible shock. Like static electricity, you feel it, but you do not see it unless it is several thousand Volts, which is plenty enough to kill components. It is less common through cable since such lines are buried, but it can still happen with a cable line, especially if it is not well grounded.
Surge protectors are only a measure of protection, and they will wear down over time. They need to be replaced periodically. Battery backups are better, assuming it is UPS. But nothing is a guarantee to stop a powerful surge.
Maybe there's a system restore point that predates the first crash.
Thanks, I had a copper lighting rod but I didn't get it connected in time. I'm not sure it was via the antenna the TV was ruint. It was a very expensive Samsung 40" TV too.
The TV still turned on but there were very large scattered magenta pink rectangles all over the screen. The TV was thrown out as after that one was bought (in 2008) larger ones became quite inexpensive.
The thing is, there wasn't actually a code on the stop screen
Hmm, that's a thought - though with luck some of the stuff I've done in response to suggestions here will have cleared any software issue 9and with luck that's all there was).
If you haven't had another BSOD since Monday I'd just let it be. If you keep having them then I'd worry.
Unfortunately I did have another just as I was putting the computer into sleep mode this afternoon.
The WhoCrashed application said:
and the same for both earlier crashes - which is mildly reassuring. I could buy the application that reports on issues, but it might be simpler just to reinstall Windows and see if that fixes things; if not I suppose it's time to start buying parts and see which, if any, fixes the issue.
Did you poke around in event viewer to see how many times this error shows up (it should be in there in some form) and see if there is a common entry always very soon before it? That may point you to the root cause...If you can find that core dump, you may be able to glimpse at a process name that caused it, though, I haven't ever worked with windows cores, only those from unix GCC....many years ago:) Most likely it's binary, but if you can open it up in an editor that doesn't mind binary blobs, you may see some readable text in there.
Using the Yandex translator, I checked what the sites in the east were saying... Didn't you tell that you had a Gigabyte motherboard?
https://generd.ru/fix/oshibka-attempted_write_to_readonly_memory-v-windows-10/
"Users have reported that the cause of this error is Gigabyte's On/Off software, so if you have This software installed, be sure to uninstall it."
"Another common cause of BSoD errors may be antivirus software. Users reported that tools such as NoVirusThanks could cause this type of error, and according to them, the problem was resolved after deleting this tool."
As much as I hate to recommend a Windows reinstall, they're such a PITA, that may be your best option. It being consistently the same error instead of random ones leans, IMO, toward it being bitrot in the file over some issue in HW. If it was me I'd give it a shot, or at least try a system restore point if you have one.
Just a note to say that having reinstalled Windows (if not yet all my appications) I haven't had a recurrence for two weeks, so it looks reasonably safe to think it was a driver or similar file corrupted by the power failures. Thank you all for your help and suggestions, they were very useful in establishing that it probably was a driver issue and that the Windows reinstall might well fix it.
(Hastily touching wood.)
