how to reverse an animation?
Hi everyone is there away of reversing an animation that you have done? For example I've completed a walk cycle for my Dino model and want it to walk backwards is there away of doing that or do I have to make the animation from the beginning?
Chears, Ian.
If you output your animated figures as sequence of TIF files, then you can re-sequence in reverse direction in your movie editor software. I do this in Flash Professional, but any multi-layer video editor should work.. I use transparent tif w/o any background for each character on the scene so I can layer the animation for a seamless end result.
If you have the Full AniMate save the cycle as a AniBlock. Load it in AniMate got to level one edit mode and do Reverse order. Send back to the DS Timeline and test. If it works save as a Standard Ani file.
That helps alot chears
