Daz Barn Installation
Hi,
Has anybody had any problems installing the DAZ Barn SKU:17045. I've tried the Daz connect and manual installation, but no luck.
Any help appreciated.
Dom
Hi,
Dom
What problems are you having?
Hi,
I've attached two screenshots of the messages I get when installing.
Thanks
The first doesn't relate to the barn, the second shows that the .duf files are present but Daz can't read the thumbnail (hence the framed exclamation mark). My suspicion would be that you installed usibng Connect (within Daz Studio) and that the files did not decrypt properly. The Daz Connect version will be used in preference to a manual (or Central/Install Manager) install. If uninstalling and reinstalling In DS doesn't fix the issue then please open a support ticket - in the meantime you can open the zip from Install manager, then the Content folder inside the zip, and drag the folders from there into /data/cloud/1_17045/ so that they overwrite the files placed by Connect and you should be good for now. I do suspect, though, that you may have other products with the same issue.
Dragging files into the data folder has worked.
Many thanks for your help.
