How to export smoothed geometry?
How to export geometry with subdivision baked in?
I'm trying to export my figure as geometry only, but there seems to be no option to export smoothed geometry. The end result will always be the blocky base geometry.
What can I do to fix this?
I only need the geometry no rigging, morphs textures, or anything at all. The format doesn't matter either as long as I can import it into blender.
If you're only interested in the geometry, OBJ format is simplest. Set the Resolution Level dropdown under Mesh Resolution in the Parameters pane to 'High Resolution' and choose the SubD level you want, then export. Import into Blender as normal, and make sure you have set the object to Shade Smooth.
