Soften Tool Anomaly
pfunkyfize
Hi all,
So when I choose the soften Tool/Brush from the UV tab and hover over the site I need to soften, I leave a trail of circle influence all over the place instead of seeing just one circle or two if I have the symmetry setting on. I've seen it work correctly before to see only one or two circles (with symmetry) but a lot of times I get the trail of blue circle influence all over the place and then Hexagon gets unresponsive after a while that I have to just close it out and restart. Am I doing something wrong or is Hexagon defaulting to something in the settings that cause this? I attached a picture of this weirdness. The symmetry setting is on and I am hovering over the model's right side with the brush and the blue trails are mirrored on the other side (as expected for symmetry)
Thanks!
Known bug. Turn off Local Redraw in the Preferences.
Thanks I'll give it a shot!
Great it works thanks!
Thank you so much! Have a nice day.
