Looking for true 3d smoke/clouds/fire.
jd641jd641 Posts: 462
I just bought this: https://www.daz3d.com/iray-clouds and while the cloulds look great, the setup is based on billboards so it's not what I was looking for. Basically I'm looking for is smoke/cloud or fire + plume that could be rotated 360 degrees and be viewed from any angle and give off the impression that it's a fully formed 3d object.
Thanks.
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,409
    edited August 2020
    you will need to use 3Delight for true volumetric clouds in DAZ studio because iray so far doesn't support it
    https://www.daz3d.com/hd-volumetric-clouds
    or in general https://www.daz3d.com/catalogsearch/result/?q=volumetric%20clouds
    all you can do is use transmapped planes in various arrangements or a software that does volumetrics such as Blender, Bryce, Carrara or if you can afford it Octane render not the DAZ studio plugin
  • kyoto kidkyoto kid Posts: 42,043
    ..I have this
    https://www.daz3d.com/cloudscape-creator-bundle
    A little expensive but it allows for making layered cloud effects. and uses actual meshes instead of billboards.
    There is also this:
  • kwanniekwannie Posts: 870
    Have you tried Animated Clouds from The Philosipher, I have it and it works great.
    https://www.daz3d.com/ireal-animated-clouds
  • jd641jd641 Posts: 462
    edited August 2020
    OOoooh those all look great!
    Would it be easy to make a plum/trail of smoke or a billowing puff of cloud coming out of a pipe/exhaust from the iReal clouds?
    Post edited by jd641 on
  • barbultbarbult Posts: 26,424
    Look at the last promo image. It looks like those are billboards. Maybe you shouldn't dismiss billboards so quickly.
  • AlbertoAlberto Posts: 1,458
    Thanks.
    You can consider Fluidos II. It can create 3D smoke,clouds and fire.
    https://www.daz3d.com/fluidos-ii-for-daz-studio
  • watchdog79watchdog79 Posts: 1,026
    I am not sure if this is what you are loking for as far as fire and smoke are concerned, but I find it amazing: https://www.daz3d.com/iray-fireworx
    I also have this: https://www.daz3d.com/sy-kaboom-iray
    You may also want to check this for smoke effects: https://www.daz3d.com/gnbd-smoke-project--4k-tiff-files
    Alberto said:
    Thanks.
    Wait whatsurprise, Fluidos works on the Mac now? And ships with 3DL mats? surprise...not in my wildest dreams etclaugh
    ...very expesnve option though.
    Yeah thinking I might just sell my car (and house)...the dog stays of courseindecision
    ...I've seen whatit can doand yes it's pretty incredible but 119$ and the fact you have to do an animation sim for the effects (which is why I don't use anything dForce) pretty much stops me right there.
    Not necessarily. It can do it without any animation in only one frame (the 0 frame).
    Yes, the dog stays!
    But, remember, in Daz there is always a sale! (in March, some people get it for $27)
    Yes, the dog stays!
    I've had Fluidos on my wishlist for the longest time. Sadly it's waaaaaay out of my price range and I missed that huge discount a few months ago. :(
  • FishtalesFishtales Posts: 6,218
    I used HD Volumetric Clouds in this render.
    Click on image for full size.
    Yes, the dog stays!
    Right:) Wishlisted:))
    I love the way it's catching and scattering the light throughout the clouds. Very well done!
    That isn't how it looks straight from the library, I had to work a fair bit with it in the Surface Tab. You have to know how the Volume settings work and how the Chromatic setting affects the light.
  • for Fire try Kindredarts Iray fireworx  https://www.daz3d.com/iray-fireworx you can manipulate the props quite a bit to make them much more realistic (reduce cutout for more see through flames...etc...)
  • MattymanxMattymanx Posts: 6,998
  • Romulus71Romulus71 Posts: 144
    Mattymanx said:
    I've used this and it is a great set of props for backgrounds and any kind of energy or fire wielding characters
  • nicsttnicstt Posts: 11,715
    Or try Blender.
