Any way to save a morph with a new name?
I need to export a collection of morphs using rules, so I go into a morph and change the parameter settings, name and label. This works fine, and I can export, however, if I close Daz and re-open, the name or label (I forget which one) has been reset, and I'm unable to export the collection name using a rule.
Any ideas?
I believe you have to click on the gear icon next to the morph and you can change the name of the morph there.
File - Save As - Support Asset - Morph Asset, select the morph(s) you want to save.
What do you actually want to do?
Do you want to change the name of the existing morph or do you want to make a copy of the existing morph?
If you just want to change the name (dial name=label) of an existing morph;
1. Load your base figure or the developer version.
2. Select "Show Hidden" in the Parameters-Tab, drop down menu (right-click)
3. Zero the figure (Found in Parameters-Tab, drop down menu)
4. Change the name of the morph/morphs (dial name=label)
5. Memorize the figure (Found in Parameters-Tab, drop down menu)
6. File->Save As->Support Asset->Save Modified Assets
Changing the actual name that can be found in properties, is not a good idea, since that is called by other morphs.
