Adding to Cart…
Good job so far. What kind of lighting are you using? The image looks a bit on the flat side.
Title: Easter Egg Hunt
Softened the shadows and added some props from the new Easter Accessories freebie from DAZ.
Thanks DAZ for the wonderful freebie.
Also resized to make sure it is within the rules for this contest.
Thank you;) I only used low sunlight from the left and uberenvironment. I didn't use a back light so maybe I'll try that. I also added a slight haze using GIMP that may have flattened it a bit. Here's the image before the haze was added. Also, now that I'm looking at it, the tree looks a bit flat doesn't it.
Thanks for the idea:)
SGCBearcub for the tree check its surface settings, Up the Bump or displacement on the Bark. Glad you liked my idea.
EDIT to ADD: I'm not sure of your level of experience but if this makes any sense to you I think it would help your image as well. On the Helm check the hanging things, Feathers and the other, for any movement type dials, tweek those so they are either hanging properly for gravity or both reacting to a wind the same. It's the little touches that often make a good image a great one.
Thanks Jaderail. Changing the size requirement would be helpful.
okay, I've somehow lost my DOF. I moved the planes so that everything in front of M4 would be in focus and everything behind him (willow tree, deer, bird) would be out of focus. Not sure what I did wrong but its all in focus now. Help?
I think you just need to narrow the DOF frames... I don't think the background stuff is really in focus, it's just not out of focus enough. To be honest I thought the DOF in your previous version was perfect (I liked the little bit of blur in the foreground). Very cool scene you have going--keep at it...I can't wait to see how this ends up.
Edited to add: I'm also wondering if the background objects might be better off even further in the distance... Not the deer, I like that where it is...the other stuff. That could help with the DOF issue, plus it would help to keep the focus on your character.
I like the bright, sunny one the best too. You might be better off just sticking with that lighting, but if you want to keep playing around with a later afternoon look, I'd say you should go really subtle with the blue hue...don't overdo it, especially on the distant light.
@SGCBearcub: You just need to Adjust the Depth again. With items in the Background the old setting is not as noticeable is all.
@Jaderail and Scott Livingston- Thanks! I got my DOF blur back.
For some of that it is the little things that can take a good image to a great image try this on your work. In the Boys hair, if possible a little hair hanging forward in the front would really add to this one in my view. Maybe other places if doable, don't over do it, but some would help.
Here's the new image after tweaking the bump settings on the tree. Thank you for pointing out the things on the helm. It never even occurred to me.
Looking much better. Do you have any displacement on the tree. It would really made the bark stand out.
Unfortunately,I seem to have pushed the displacement as far as it can go. Any higher and the bark looks all spikey. Thanks for the idea though.
What are you using as a displacement map? Are you just plugging in the bump or do you have an actual black or grey and white. A lot of times just using the bump as your displacement works pretty well.
I used the grey map that was plugged into the bump channel. Is that right?
You can but you won't get the best results. A black and white is what it should be or a grey white. Its easy to make one. If you have photoshop just copy the texture map, desaturate it and adjust the levels Till you get good detail on the bark
Thank you ! I'll try that.
Thank you Sensei.
That is something I should have thought of myself. I was so preoccupied with the DOF & lighting I missed that detail.
Thanks for the comment. Maybe I will make some experiments with the afternoon mood, but seems like I have made my final version.
This is my first contribution to the new users contest, better to ask this now:. Postwork is allowed, if I understand the rules correctly?
Added a bit of a Vignette effect in postwork. For comparison I will attach the plain render again.
Some comments would be nice ...
Impressive. Great job. I'm really liking the lighting and the DOF is perfect
So I should post this quickly to the entrys thread, before the afternoon mood hits me again. :-)
Happy Easter to everybody!
LOL, yes post it. You can always change it later if you think of something else. I would pick one of them and post it. If you post both then that will be your 2 entry limit.
It is a great render MN-150374.
Love the Rabbit render. Well done and happy you came and joined the contest.
Thanks for the compliments. :red:
Followed Franks proposal and added the plain render too.
Here's what I have on my second entry so far:
