Duplicate formulas found. . .
cclesue
Whenever I load a new base figure I get [Duplicate formulas found. . .} this flag. How do I fix this problem?
here's what i do:
launch studio. load your base figure in an empty scene. generate those errors.
then go to Troubleshooting/View Log in the rightmost studio dropdown menu--i think it's Help.
the log should open in your text editor of choice. quit studio, then, but keep your log file open.
search for 'duplicate', and the log will show you the full paths and names of the files that are generating the errors. go into your studio library's base data folder and find 'em in the appropriate Morphs folder for the figure you're working with.
i transfer them into a new folder in the base figure directory named Morphs-Disabled then, rather than deleting them. you never know...
you may have to work through quite a few 'duplicate' results in your log file to find them all.
(if you've only started having this problem recently, the culprit is likely either a product you've just installed, or a g3-to-g8 type morph conversion you've done recently.)
once those morph files are all cleared out of your base figure's Morph folder, restart studio, and try loading your figure again.
good luck!
Please remember to make the text of your post complete in itself.
Once you have applied the methods listed by jardine don't forget to report the products to Daz (for items purchased here) or to the vendor/creator.
